Honda S2000 Honda S2000
Front Plate Removal Question
Old Jun 4, 2003 | 12:55 PM
Mocky57's Avatar
Default Front Plate Removal Question
Quick question.. how many bolts are holding that front plate? I want to get mine off tonight and figured I'd ask before I go home and take it off.. Should be relatively easy.. (at least I'm assuming it is).. 2 holding the plate and front, and 1 underneath? is that it? Thanks in advance.
Old Jun 4, 2003 | 01:11 PM
PornStarRacingB16T's Avatar
Default Re: Front Plate Removal Question (Mocky57)
Depends on what bracket they used. I have seen a couple of different ones, but I think they all mount in similar ways. There are two 10mm (if I remember right) bolts holding the plate to the bracket. Then two more securing the bracket to the holes in the bumper (these are concealed by the plate). Then one holding the little arm that extends from the bottom of the bracket into the grill. Just pull off the plate, remove the 3 bolts undeneath, get yourself some honda bumperplugs matched to your paint and viola! Clean front end
-J
Old Jun 4, 2003 | 02:44 PM
Mocky57's Avatar
Default Re: Front Plate Removal Question (PornStarRacingB16-T)
thanx. i'll be under the car in 30 minutes...
gotta get the car ready for route26 Ohio S2ki Run this Saturday.
Old Jun 5, 2003 | 05:25 AM
Mocky57's Avatar
thanks for helping me out with the completely non-technical question. car looks a lot better w/o the front plate.
Old Jun 5, 2003 | 05:38 AM
No doubt, now just watch out for the coppers =P (if you're in a state that requires front tags). Here in MD the ticket isnt a biggie its just like 50 bux and you dont even have to put it back on. If you just get one every once in a while and pay it, not a big deal
-J
Old Jun 5, 2003 | 07:03 AM
Mocky57's Avatar
that's true..ohio does have a front plate law....which is quite annoying... $50 ticket isn't the concern..my concern is..will it go on my MVR. I don't want an Equipment violation on my record.....or does it?
Old Jun 5, 2003 | 07:30 AM
I have no idea how Ohio does it, but I dont *think* its a moving violation here in MD at least. So I doubt it affects you negatively anyway. TOTALLY WORTH IT =D
Old Jun 5, 2003 | 06:16 PM
Mocky57's Avatar
DOH.
put the plug in for the right 2 holes, but on the left 2 holes, the holes are significantly bigger (and no threads).
is the part # for the left plug different from the right? am i missing something here?
Old Jun 5, 2003 | 07:14 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mocky57 &raquo;</TD></TR><TR><TD CLASS="quote">DOH.
There should be threads on both sets of holes. On the inside of the bumper, there is a metal piece that are what makes that part "threaded". It's hard to explain. But yeah, if you order the plugs from Honda, both sides are the same.
I believe they are $6.38 each. I got them a couple of weeks ago. Looks great.
Old Jun 5, 2003 | 08:22 PM
Mocky57's Avatar
Default Re: Front Plate Removal Question (shamoo)
shxt...both sides have threads huh..weird..
only my right hole had threads.... wtf is going on.. *sigh*..i'm not going to be a happy camper when i see my dealer.
Stonage07
Paint and Body
Oct 2, 2015 09:13 AM
lickety_britches
Jun 20, 2009 02:15 PM
mushroom samba
Mar 16, 2009 04:41 PM
yed
Honda Civic (2006 - 2015)
40
Jun 4, 2007 08:11 PM
