Clutch Poll
Old Jun 4, 2003 | 11:00 AM
Propulsion's Avatar
Default Clutch Poll
hi guys, Im in the market for a new clutch, please help me decide...
feel free to add your own, I accidentally clicked enter too fast and didnt enter "action, exedy, and other brands"
Old Jun 4, 2003 | 11:04 AM
Back in Black's Avatar
Rather OG
Default Re: Clutch Poll (SilverCIVIC96)
You should search, but my Exedy has worked great for me so far.
Old Jun 4, 2003 | 11:20 AM
ArmyGreenITR's Avatar
Default Re: Clutch Poll (Jason Franza)
i have a CM stage 2 in my 97 hype r it works great for an every day clutch.
Old Jun 4, 2003 | 11:26 AM
13secR's Avatar
act. i have a stage 2 in my car and its awesome
Old Jun 4, 2003 | 12:12 PM
NXSpoon's Avatar
What's up w/ the "Anything but Exedy" choice?? I have been running one w/ a Toda flywheel on my Si now for more than a year. Other than some chatter when cold, this setup works great for me. Did I get lucky??
Old Jun 4, 2003 | 12:44 PM
B18CXr's Avatar
ATS and Exedy are tops in my book
Old Jun 4, 2003 | 01:28 PM
Propulsion's Avatar
Default Re: Clutch Poll (B18CXr)
what about Action? Ive heard great things about them...
Old Jun 4, 2003 | 01:35 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">what about Action? Ive heard great things about them...
Action (not ACT) kevlar here. 21,000mi with no problems. Stock like feel and loving it.
Old Jun 4, 2003 | 01:58 PM
SoCal ITR's Avatar
Default Re: Clutch Poll (ActiveAero)
ACT
It's great so far.
Old Jun 4, 2003 | 02:16 PM
Propulsion's Avatar
Default Re: Clutch Poll (SoCal ITR)
someone plz add Action to the poll...
Old Jun 4, 2003 | 02:32 PM
MiraiZ's Avatar
ACT is what I have...grabs well, but the chatter bothers me somtimes....only happens at idle...and intermittently though.
Old Jun 4, 2003 | 02:50 PM
kungfuSiR's Avatar
Default Re: Clutch Poll (MiraiZ)
CM Stage 3 with CM aluminium flywheel, great setup
Old Jun 4, 2003 | 06:01 PM
Tommy_Gunns's Avatar
Action Kevlar here
Old Jun 4, 2003 | 06:48 PM
Asahi's Avatar
Default Re: Clutch Poll (NXSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXSpoon &raquo;</TD></TR><TR><TD CLASS="quote">What's up w/ the "Anything but Exedy" choice?? I have been running one w/ a Toda flywheel on my Si now for more than a year. Other than some chatter when cold, this setup works great for me. Did I get lucky??</TD></TR></TABLE>
Your SI isn't an R and the Type-R has been seen to have plenty of problems with the Exedy OPrganix.
My vote goes to Stock or ACT if you need something other than stock.
Old Jun 4, 2003 | 07:01 PM
ultimatehonda's Avatar
Default Re: Clutch Poll (Asahi)
Yea its funny....All the si owners I know love the Exedy, Then all the R owners hate it....lol
Old Jun 4, 2003 | 07:03 PM
CivicNA's Avatar
My imput is that i think that act is the worst clutch ever made. i know at lease 5 people personaly who have had mojor clutch problems with act. from getting weak very fast(me) to the splins stripping out to exessive chatter/ slipping to straight blowing up. all sept the one with the splines stripping out had very low miles on them below 7000 . i still have my stage 2 and it seems worse than my old CM stage 1 in my old ls motor (now i have a itr motor). i am going to switch to CM stage 2 or 3 maybe try the new CM multi plate system ill leave a thread on the multi plate if i get it in......
Old Jun 4, 2003 | 07:08 PM
Mires's Avatar
Default Re: Clutch Poll (CivicNA)
I have a ACT stage 2 in there now and it has been pretty good. Explain to me what exactly do you mean when you say chattering?
Old Jun 4, 2003 | 07:09 PM
2k1_ITR_0736's Avatar
act stage 4 look the f*ck out.
Old Jun 4, 2003 | 07:10 PM
ScaleExtric's Avatar
Well depending on what your mods or plans are with the car...I wouldnt go off neutral advice here..considering..every different company may or may not have the right application for your needs
Old Jun 4, 2003 | 07:45 PM
CivicNA's Avatar
about the chattering a guy i knew was saying something to the efect that his pressure plate was some how defective and was making this funky noise when working the clutch moderitly. i never saw his stuff but he said.
Old Jun 4, 2003 | 09:37 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
You should also note what kind of power your car will be making and what it will be used for.
I for one know my car will never make extreme power levels (probably never more than 200whp). I was also very happy with the stock ITR clutch pedal feel. That said since I was replacing it I wanted to put something in there that would last, have smooth engaugement, and a soft pedal (like stock). Therefore I went with the Action Kevlar disc with the single diaphram pressure plate. I had an issue with it slipping with only a 1,000mi on it after I did a few back to back 7,000rpm drag launches (with no cool down time mind you), but then I was informed on Kevlars high friction/heat producing properties. I have since had NO problems with it after 20,000mi of use.
Search in the archives under the heading: clutch 101 by user Rocket. This should cover everything you should need to know.
Old Jun 4, 2003 | 10:30 PM
VTHokie's Avatar
Toda clutch which is made by the same company that makes exedy . I had the ACT HD pp and street disc and i like that too. But I have heard bad things about ACT (basically rebuilt stock clutches) blowing tranny's and not being able to handle high revs. But I never had a problem with mine, sometimes i miss it. But toda clutch is good chit! ~ 13k miles and handling 9k rpms like a champ
Old Jun 4, 2003 | 11:47 PM
98itR484's Avatar
Default Re: Clutch Poll (VTHokie)
CM clutch, CM fw, been using them for years, drag racing/road racing, never failed
Old Jun 5, 2003 | 02:04 AM
Mr.Hatch's Avatar
Default Re: Clutch Poll (98itR484)
I've had my Exedy for about 9 months on a stock hype R motor with no problems whatsoever. So i give it
Byaaah!
11
Jan 27, 2007 09:35 PM
tech6804
Oct 2, 2004 08:26 AM
UpstateCivic
Apr 15, 2004 08:19 AM
B18CXr
Feb 23, 2004 09:55 AM
deeweezy
Aug 6, 2003 01:24 PM
