Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Gauges: Mechanical vs. Electrical
Old Jun 4, 2003 | 08:56 AM
RacerBowie's Avatar
Default Gauges: Mechanical vs. Electrical
Looking at purchasing/ installing some good gauges in the race car.
RacerPartsWholesale sells some nice Longacre gauge panels (water temp and oil pressure panel is what I am looking at, $169.95)
These are mechanical gauges. Is this an issue? What sort of issues, if any, am I going to run into installing mechanical gauges that I wouldn't have installing electrical? Which is better? Which is easier?
Bowie
Old Jun 4, 2003 | 10:04 AM
Track rat's Avatar
Default Re: Gauges: Mechanical vs. Electrical (RacerBowie)
I'm a fan of electrical becuse they are easier to install, and you don't have to pump hot fluids into the cockpit. Some may argue that Elec. guages are less accurate, but I argue that a 2-5% difference doesn't mean squat in the club racing world!
(BTW, what does a "drive it till it blows up" guy like Bowie need guages for? )
Old Jun 4, 2003 | 10:50 AM
RacerBowie's Avatar
Default Re: Gauges: Mechanical vs. Electrical (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">I'm a fan of electrical becuse they are easier to install, and you don't have to pump hot fluids into the cockpit. Some may argue that Elec. guages are less accurate, but I argue that a 2-5% difference doesn't mean squat in the club racing world!
(BTW, what does a "drive it till it blows up" guy like Bowie need guages for? )</TD></TR></TABLE>
From the sounds of things, these autometer mechanical gauges don't actually pump any hot fluids...they heat ether in capillary tubes to activate the needles.
I know I don't need gauges....it would just be nice to look down and go "damn, it's gonna blow up!" right before it did!
Old Jun 4, 2003 | 11:56 AM
krshultz's Avatar
I *thought* the electrical gauges would be easier to install...not so. My plan was to use the oil filter relocation plate as a gauge sender mount. I got a plate with two in/out pairs...one for oil, one for senders.
Well, the oil pressure sender for my VDO electric oil pressure gauge is enormous. I had to completely reengineer the whole deal. When they leaked I finally ended up breaking one of the senders and having to reengineer the thing AGAIN.
I'm with Track rat...who needs 'em? Its like a car alarm. All that tells you is that someone just broke into your car and stole your stuff.
Old Jun 4, 2003 | 12:33 PM
johng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerBowie &raquo;</TD></TR><TR><TD CLASS="quote">
Is this the case for all Autometer bits? I'm interested in keeping an eye on oil pressure, oil temperature, and water temperature, but I'm still on the electrical/mechanical fence like you.
Old Jun 4, 2003 | 01:39 PM
JHill's Avatar
Default Re: Gauges: Mechanical vs. Electrical (johng)
I have the Autometer electrical water temp. It was pretty simple, the sensor has a couple wires and a connector on it. Then you have to install a box with several leads for power and input/output. Works really well.
The oil pressure guage I use is mechanical (autometer) and runs a plastic line to the guage from the block. This is very simple too, but at a minimum I will probably be looking to upgrade to a braided line. One of the guys in Seattle had the line break in the engine bay above the exhaust, and the car looked like a fireball to the corner workers.
Cap'N Chronic
Engine Management and Tuning
Oct 25, 2011 02:23 PM
Legendaryyaj
Oct 23, 2004 08:07 PM
p1ccoloz
Aug 3, 2004 12:21 PM
Tommy_Gunns
Dec 7, 2001 01:23 PM
johng
Aug 13, 2001 10:33 PM
