How to take off the RSX steering wheel
Anybody know where I can find the procedure? I searched but found nothing.
Just wondering where are all the bolts and how to disconnect the airbag. Going to change it to a OMP wheel.
If you can't find the answer, go and get yourself a Helms Manual (hope this link works). This will definitely have the stuff you need. Best $70 you'll ever spend.
Helm website
Helm website
If you want to remove your steering wheel. It is pretty easy. There should be two holes with plastic covers over them. Remove the plastic covers and there should be a 10mm bolt underneth (I am not sure on the size). That is what keeps the airbag in place on the steering wheel. Pull it out really carefully, then unplug the horn and the ABS. You should be able to see the steering wheel nut. Your going to have to take that off and have a steering wheel puller handy. Its a bitch if you do it by hand. You know that if you disconnect the ABS plug your ABS light is going to come on!!! You also know that in order to prevent the ABS light from staying on you need the Splash Boss Steering Wheel Hub or some kind of hub that will bypass the ABS sensor, right?? Other than that the install should be pretty simple. Dont for get to disconnect the battery.
