help me decide motor
Old Jun 4, 2003 | 07:55 AM
mini-cRx's Avatar
Default help me decide motor
2.0 typer motor 13:1 comp full built gsr head p&P with toda d ericks **** and built tranny 4.7 fd and quife
or ls sleeved lsvtec 2.0 fully built 13:1 comp with gsr fully built head and P&p and toda c and same tranny
and give me your knowledge also
Old Jun 4, 2003 | 08:35 AM
allmotorgsrhatch's Avatar
type r boitch!
Old Jun 4, 2003 | 08:37 AM
Suprdave's Avatar
Default Re: (1fastcivichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastcivichatch &raquo;</TD></TR><TR><TD CLASS="quote">type r boitch!</TD></TR></TABLE>
I doubt this was the kind of responses he was looking for.
Old Jun 4, 2003 | 10:50 AM
dfoxengr's Avatar
Default Re: help me decide motor (mini-cRx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx &raquo;</TD></TR><TR><TD CLASS="quote">2.0 typer motor 13:1 comp full built gsr head p&P with toda d ericks **** and built tranny 4.7 fd and quife
and give me your knowledge also </TD></TR></TABLE>
well both of these blocks are the exact same.
Old Jun 4, 2003 | 11:27 AM
dkim48's Avatar
Default Re: help me decide motor (hybridvteceg)
go for whats in your sig
but if you are going all motor then go with the first setup. they are basically the same but those d's will go well with the 13.1 comp. Either way good luck
Old Jun 4, 2003 | 01:54 PM
Mr Hammond's Avatar
a/k/a Jomo
Well why go D's with one and C's with the other? That is a pretty big factor right there. Why waste your money on an ITR block and not GSR if you are rebuilding it? Save money. How are these blocks the same again hybrid? 87.20mm vs 89.00mm?
Old Jun 4, 2003 | 01:56 PM
dfoxengr's Avatar
Default Re: help me decide motor (Mr Milano)
both blocks are 2litre.
technically the same. because both have to be sleeved, the LS will be an 84 x 89 b/s, and the R 84 x 87.2.
Old Jun 4, 2003 | 05:39 PM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well why go D's with one and C's with the other? That is a pretty big factor right there. Why waste your money on an ITR block and not GSR if you are rebuilding it? Save money. How are these blocks the same again hybrid? 87.20mm vs 89.00mm?</TD></TR></TABLE>
He's got some very good points.You should just get a gsr block instead of the ITR or you can have a gsr block with ls crank pistons and rods.That would be good power.
Old Jun 4, 2003 | 06:06 PM
dfoxengr's Avatar
Default Re: help me decide motor (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">
He's got some very good points.You should just get a gsr block instead of the ITR or you can have a gsr block with ls crank pistons and rods.That would be good power.</TD></TR></TABLE>or since thats the same as an LS block, be cheap and buy just an LS block
slowteg550
Apr 14, 2009 05:47 AM
jay-d-em
Northeast (Sales)
11
May 24, 2008 04:02 PM
civicstar
Aug 26, 2006 04:29 PM
PFSeg
Nov 4, 2004 04:05 PM
mini-cRx
Jun 5, 2003 10:03 PM
