H22 Swap, what axles to use
You REALLY need to search.
But i will help you out. If the car is not droped and is running a mostly stock motor then you can use a 90-93 Accord Intermeadate shaft and 90-93 Integra Axles. If they "bind" then drop to 89 teg axles they are arround 1" shorter. That is likely needed if the car is droped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">You REALLY need to search.</TD></TR></TABLE>
Could not have said it better myself.
I typed in "H22A Axles swap" under archived and got:
https://honda-tech.com/zerothread?id=487398
https://honda-tech.com/zerothread?id=482674
https://honda-tech.com/zerothread?id=305010
https://honda-tech.com/zerothread?id=231922
https://honda-tech.com/zerothread?id=121411
