injectors if you are switch from si to vtec injectors do you need the resistor packs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlude69 »</TD></TR><TR><TD CLASS="quote">do you need the resistor packs switching from 4th gen si to vtec injectors</TD></TR></TABLE>
if they are both from the 4th gen (P&H) then you still use the resistor pack that it already has. if you get them from the 5th gen (saturated), then you need to remove the resister pack and wire them differently.
would you happen to know how you wire them differently? i switched to saturated already but didnt remove them yet.
Mike95lude
Jan 14, 2008 11:29 AM
caliprelude3087
Nov 18, 2004 01:27 PM
