direct replace low profile fans?
if your looking for (turbo) clearance, you might try going with a "pusher" fan. These go in front of the radiator and "push" air thru rather than "pull". They are not as efficient but if your not doing alot of idling in city-driving, you should be okay. I would guess check the flow rates vs. whatever capacity you need.
I've seem them at SCCA and domestic performance type part-shops. But probably an outfit like NOPI would stock them too.
yeah I was thinking about the pushers but I do not have any more room in front of the radiator.
It is not really a problem clearance wise, but I would like a bit more room to work.
bigchris2000
14
Aug 6, 2010 08:25 PM
