Timing wont line up?
I'm just wonding, am I off a tooth or something because I let the car idle at about 650rpm and I cant get the timing lined up when the distributor is fully cranked... Thanks!!
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK »</TD></TR><TR><TD CLASS="quote">I'm just wonding, am I off a tooth or something because I let the car idle at about 650rpm and I cant get the timing lined up when the distributor is fully cranked... Thanks!!</TD></TR></TABLE>
before you go ******* with that...did you:
jump the service connector
are you using the right timing marks and can you see them (mine were so faded i couldnt even see them)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK »</TD></TR><TR><TD CLASS="quote">Jump the service connector? Explain please...</TD></TR></TABLE>
http://www.norcalcrx.org/ht.html#ignition....try that
And yeah, I took some whiteout and a black pin and marked the middle notch...</TD></TR></TABLE>
There is a little connector underneath the passenger side dashboard. It has a blue end, but I can't remember the wire colours(it's the only open connector there) just ground it out and then set the timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 »</TD></TR><TR><TD CLASS="quote">
http://www.norcalcrx.org/ht.html#ignition....try that</TD></TR></TABLE>
Did it step by step, didn't work...
Ok, now what?
Ok, now what?
Ok, now what?</TD></TR></TABLE>
if you followed the timing procedure and you still cant see the marks then your more than likely off a tooth or something. make sure your light is working correctly before you go ripping everything apart. also if you cant see the marks holding the light straight down at it hold the light off at an angle and see if you can see your marks.
Did you make sure the car was warmed up properly?
I had the same problem, the pulley's weren't off and it was idilng right but the marks just wouldn't line up. I tried again the next day and had the same problem. The third day I tried again and it mysteriously lined up.
Moral of the story? keep trying
allnaturalb16
21
Aug 14, 2007 08:57 PM
X2BOARD
Jul 2, 2005 09:27 PM
