Which tranny is better?
Old Jun 3, 2003 | 01:19 PM
BseriesHatch's Avatar
Default Which tranny is better?
Which tranny is better, the ZC or Si tranny? I heard that the Si final drive is a 4.25 and the ZC is a 4.45. I also heard that the ZC has a 3.88 final drive but shorter gears. Can someone clarify this for me?
Old Jun 3, 2003 | 01:24 PM
elmalouno's Avatar
Default Re: Which tranny is better? (Novtec)
better is relative...
the zc will get up and going a bit faster, but with higher rpms at highway cruising speed as a down fall. the si is the reverse of that... and the dx is to the si as the si is to the zc in this example.
check this link out ---> http://crx.honda-perf.org/math/index.html i love it...
Old Jun 3, 2003 | 07:00 PM
jlicrx's Avatar
the stock Si has 4.25 final drive - the ZC has 3.888 final drive (same as DX) -
Si - 1st:3.25 - 2nd:1.894 - 3rd:1.259 - 4th:0.937 - 5th:0.771
ZC -1st:3.25 - 2nd:1.944 - 3rd:1.343 - 4th:1.033 - 5th:0.878
the best set-up is the ZC with Si final drive and if you want lower rpm's in 5th, use the HF 5th gear which is 0.694 or the Si 5th
Old Jun 3, 2003 | 07:07 PM
Denny317's Avatar
i went with the zc gears and the Si FD with my old zc turbo setup. worked great if you ask me
Old Jun 3, 2003 | 07:18 PM
pokemon's Avatar
Kinda of a diff question but has anyone heard that if you use a jdm ZC motor with a USDM D-series transmission that the starter won't line up?
Old Jun 3, 2003 | 07:34 PM
blah13's Avatar
Default Re: (pokemon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pokemon &raquo;</TD></TR><TR><TD CLASS="quote">Kinda of a diff question but has anyone heard that if you use a jdm ZC motor with a USDM D-series transmission that the starter won't line up?</TD></TR></TABLE>
My starter lines up prefectly. ZC with a 90EX tranny.
Old Jun 3, 2003 | 09:27 PM
91hatch_on17's's Avatar
Default Re: (blah13)
since this topic is about trannies, I was wondering how much is a decent Si tranny worth?
Old Jun 3, 2003 | 09:33 PM
elmalouno's Avatar
Default Re: (91hatch_on17's)
150 bux... in good good shape
Old Jun 3, 2003 | 09:39 PM
USDM 4G VTEC's Avatar
Default Re: (elmalouno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">150 bux... in good good shape</TD></TR></TABLE>
now thats a lil overated
all the 88-91 trannies that have never been opened are very likely to have the differential pin worn out and be waiting to blow.... as a example i blew my Si tranny open like an egg 3 days ago bc of that pin...
all i say dont pay no more than 100 for a tranny, and get urself someone that will open it and replace the diff pin.... that way u make sure u dont brake that,... as the second thing that brakes on them are bearings and select forks....
the select fork that alway s breaks its usually 1st and 2nd one.... wich costs 70 bucks at honda.....
other than that u can have one that u can beat up for a while
alx_90ef
13
Sep 29, 2009 04:24 AM
NightHawkC5
May 2, 2006 04:28 PM
DOHClessEF-9
Feb 16, 2005 07:56 PM
QuarterMileMaster
Aug 26, 2004 10:59 AM
1990hondaHF
Jul 8, 2002 08:31 PM
