what can i do to make the y8 fast?
Old Jun 3, 2003 | 07:54 AM
crashtest Sonny's Avatar
Default what can i do to make the y8 fast?
i want to at least beat b16a/b18c or at least keep up.
Old Jun 3, 2003 | 08:11 AM
civicdragger818's Avatar
Default Re: what can i do to make the y8 fast? (4g_civic_si)
NOS.......or Homemade turbo. If you want to keep it all motor then put in some ZC pistons, Put in a better cam and have the IM honed or get a new one for better flow. Possibly some head work and you will be there.
Old Jun 3, 2003 | 08:13 AM
Default Re: what can i do to make the y8 fast? (civicdragger818)
what kind of cams are good? i have a 96 ex manifold..is that good enough? or an aftermarket one?
Old Jun 3, 2003 | 08:38 AM
You have a D16y8 manifold and that is the best sohc intake mani that honda makes. I would probably just keep that then dont worry so much about having that honed.
Old Jun 3, 2003 | 08:41 AM
oh ok.. what kinda cams are good? i have most of the bolt ons already. headers, intake, need exhaust.
Old Jun 3, 2003 | 09:11 AM
Ef Whore's Avatar
Turbo.
Old Jun 3, 2003 | 09:12 AM
Default Re: what can i do to make the y8 fast? (Ef *****)
what kind of turbo, and how much?
Old Jun 3, 2003 | 10:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">what kind of turbo, and how much?</TD></TR></TABLE>
Thats where you need to sit and learn about how a turbo works first off then deside which turbo is best for your needs.
Old Jun 3, 2003 | 11:44 AM
Creepshow S60's Avatar
you could always go the junkyard turbo way i suppose. it sounds to me like you're on a limited budget, so that's what i'd do.
Old Jun 3, 2003 | 11:47 AM
SimbaDogg's Avatar
there's plenty of things u could do to make that sohc vtec quik besides turbo or nos. u could do a all motor build up, wont give you the times that a built b18c or b16 would give you, but you can get that motor pumping...and if you built the bottom end and wanted to get a lil more "umph" outta it, u could always throw in a 40 shot or so.
Old Jun 3, 2003 | 12:33 PM
Default re
well my vtec is hooked up to a button..very ghetto..supposily its for temporary..but i dont know any other way to hook up vtec and make it engage at 4400..any suggestion? i hear hook up a shift light to it would work..but i dont want that thing to blind me from 4400-6700. i have an led light..and planning to drill it into my cluster..so ill know when vtec hits..but i still need to let vtec engage automatically everytime at 4400.
Old Jun 3, 2003 | 12:49 PM
Default Re: re (4g_civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">well my vtec is hooked up to a button..very ghetto..supposily its for temporary..but i dont know any other way to hook up vtec and make it engage at 4400..any suggestion? </TD></TR></TABLE>
You can get a RPM activated switch. Something else that I would recomend besides this is rewire for OBD1. That would be the most beneficial to you seeings how your running OBD0 at the moment. REwire and the run a P28 and your going to see a decent power increase from that.
Old Jun 3, 2003 | 12:50 PM
4drEF's Avatar
Keyboard Humorist
You could use an RPM activated switch, shift light, vtec controller (VAFC will let you adjust for a fuel bump when vtec engages), or convert to OBD-1.
Old Jun 3, 2003 | 01:19 PM
Default Re: re (civicdragger818)
does it cost a lot of money to conver to obd1? and how hard? what do i need to change?
i had an rpm activate switch..but it didnt work..
Old Jun 3, 2003 | 03:33 PM
You need a ECU and a ecu plug conversion harness and I dont know what else is involved. Do a search and I think you will find some stuff. Or else just find someone with a EF that has already done it and IM them.
Old Jun 3, 2003 | 05:02 PM
SimbaDogg's Avatar
if its the same as doing a b16...
injectors, distributor, ecu
Old Jun 3, 2003 | 06:36 PM
platinum00's Avatar
Default .
i have a y8, there is nothing you can do to that motor that will make you happy, but put a turbo on it.
that motor loves boost, NA on that motor is a waste of money. just save for the power you want and get a turbo.
this is from trying everything before giving up and going turbo. my turbo at 6psi puts out more power then my y8 did with new cam, cam gear, header , exhuast, port pollish. 3 angle valve job, new springs , valves, vtec controller, blah blah blah.
dont start the wasted process.
if you want a little more power sure, it's worth it, but power is a addiction. once you get a little you want a lot.
have fun, and save for what you want.
Old Jun 3, 2003 | 06:42 PM
Racer613's Avatar
You are running 6 lbs on stock internals, or is it mildly built? I am asking because I had blown my old D16y8 and had to get the same engine..(insurance) I really wanted to put in a b18a with some boost...but alas, it was not meant to be.....I have my h22/crx so Ill be fine..but I want to t charge the d16y8 and be at least a little quicker than some stock b16s. If I am not going to build the sohc and wanted to run f/i, what do I need to run boost wise?
Thanks all, you the men!
Old Jun 3, 2003 | 06:48 PM
platinum00's Avatar
Default Re: (Racer613)
i a little built. i have new pistons, rods, rings, and block gaurd. , i will be running alot more boost once i get my GOD DAMN injectors from this dude i think ripped me off. anyway.
but you can run 6 psi on a stock y8 all day long. 8-10 if your lucky with just a new fuel pump..
Old Jun 3, 2003 | 11:49 PM
Racer613's Avatar
so I can run up to 6 lbs of boost all day? Cool! What type of t kit could I get for under 1500 that is good qual?
6 lbs will give you how much hp?..to the wheels? On a d16y8, 2 1/4" exhaust, MSD 6AL, upped injectors, fp Regulator, and 105 oct.? Thanks
Old Jun 3, 2003 | 11:52 PM
SimbaDogg's Avatar
you can make a sohc vtec pretty quik. my friend an i raced from 20-100 and he was w/ me the whole way. he has a sohc vtec with, i/h/e, stock block and head and full interior. i was actually surprised. if he woulda had cams, intake manifold, and bottom end done...he woulda beat my ***.
Old Jun 3, 2003 | 11:53 PM
SimbaDogg's Avatar
forgot to mention, he was in an eg hatch, quite a bit heavier than a rex.
Old Jun 4, 2003 | 03:31 AM
platinum00's Avatar
Default ,
6psi with that setup. not sure hp wise. depends on your tuning but with the 103 oct.
prolly around 160 - 170 whp, does not sound like thta much. but think of it this way b16 has 160 cracnk power. so like 130-140 whp maybe.
it's enough to have fun. do a little bit of work on teh engine and you easily see over 200 whp.
also remember a swap will cost you around 3k installed.
Old Jun 4, 2003 | 06:35 AM
Default Re: , (platinum00)
Turbo does rule all!!!! Just dont be a dumbass with it and want to turn up the boost everytime you get in the car. Power is an addiction and once you have it you just want more.
Old Jun 4, 2003 | 06:40 AM
one slow d16's Avatar
Default Re: . (platinum00)
running a y8 in a crx is A LOT different then running it in an ek.
