Stand alone users, what do you set your Target Air Fuel Ratio to while driving.......
Old Jun 3, 2003 | 07:49 AM
turbo Si's Avatar
Default Stand alone users, what do you set your Target Air Fuel Ratio to while driving.......
What are you guy's setting it to while driving on the freeway at half throttle. I'm working on my gas mileage, and have been experimenting with it a bit and just wanna see what everyone else has theres set at. For instance, under vacum, I have my AF ratio set at 16.0 from 4000 to 8000 rpms. This is only when I am driving on the freeway with no boost what so ever. So far i'm on target to get 20 miles per gallon.
So share any ideas you might have on this issue .
Old Jun 3, 2003 | 07:59 AM
Bottoz's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (turbo Si)
Here's mine.
Bottoz
Old Jun 3, 2003 | 09:53 AM
salt's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (Bottoz)
hey bottoz:
can you show me your timing map like that as well? I've advanced mine, and it feels like its making more safe power, but I'd like to see if I'm too agressive, or if it normal for 94 octane and 9.3:1 compression.
steve
You must get good gas milelage by running a little lean while in low load.
Old Jun 3, 2003 | 10:23 AM
turbo Si's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (salt)
What map is that from, Hondata?
Old Jun 3, 2003 | 10:24 AM
metal-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo Si &raquo;</TD></TR><TR><TD CLASS="quote">What map is that from, Hondata? </TD></TR></TABLE>
AEM ems
Old Jun 3, 2003 | 11:03 AM
turbo Si's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (metal-x)
DAMN, I can't believe I didn't see the logo. That reminds me, I need to call about my refund!
Old Jun 3, 2003 | 06:20 PM
turbo Si's Avatar
Anyone else?
Old Jun 4, 2003 | 12:06 PM
turbo Si's Avatar
up!
Old Jun 4, 2003 | 01:08 PM
LEON's Avatar
Off boost is set for 14.7 and 1 degree advance in timing (GSR with Drag kit and Hondata). I'm getting ~27city / 32hwy
Old Jun 4, 2003 | 01:20 PM
turbo Si's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (LEON)
Damn....i'm getting like 20-22
Old Jun 4, 2003 | 01:27 PM
Mase's Avatar
I ran closer to 15.5:1 to 15.7:1 while at crusing speeds.
Old Jun 4, 2003 | 01:32 PM
turbo Si's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (Mase)
Damn, so i guess i set mine the highest so far!
Old Jun 4, 2003 | 03:32 PM
Evil DOHC's Avatar
From my experience 14.5 is excellent for part throttle on a turbo car.
EVIL
Old Jun 4, 2003 | 04:28 PM
Bottoz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt &raquo;</TD></TR><TR><TD CLASS="quote">hey bottoz:
steve
You must get good gas milelage by running a little lean while in low load.</TD></TR></TABLE>
Here ya go, During VTEC I have it set for +2º. Also, if you scroll up I've updated my TargetAFR to my current scales.
Bottoz
Old Jun 4, 2003 | 04:34 PM
turbo Si's Avatar
What is your timing at idle?
Old Jun 4, 2003 | 04:42 PM
93LSivic's Avatar
Looks to me to be abour 16.4.
Your timing maps are pretty conservative IMO. I run about 23-24 degrees up top.
Old Jun 4, 2003 | 04:46 PM
Bottoz's Avatar
Bottoz
Old Jun 4, 2003 | 04:47 PM
Bottoz's Avatar
Default Re: Stand alone users, what do you set your Target Air Fuel Ratio to while driving....... (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Looks to me to be abour 16.4.
Your timing maps are pretty conservative IMO. I run about 23-24 degrees up top.</TD></TR></TABLE>
Thats about where it is, I said during VTEC its +2º.
Bottoz
Old Jun 4, 2003 | 05:29 PM
93LSivic's Avatar
Hehe, oh ya. I dont need to tune no stinkin vtec
Hows your idle? Are you on 94?
Old Jun 4, 2003 | 05:34 PM
Bottoz's Avatar
Yes .94. Idle is fine, 800-825 Rpm.
Bottoz
Old Jun 4, 2003 | 05:43 PM
Mase's Avatar
idle is easy, its tip in throttle that is a bitch
Old Jun 4, 2003 | 05:52 PM
turbo Si's Avatar
What the timing on a stock ecu?
Old Jun 4, 2003 | 06:02 PM
Bottoz's Avatar
Stock ECU is not programmed to see boost.....but here is an image compliments of the AEM board.
Bottoz
Old Jun 4, 2003 | 06:46 PM
turbo Si's Avatar
Oh, I know that. I just wanted to see what timing is set at idle on a stock ecu. Compared to yours, mine is totally different at idle. My tuner set mine at 44 degrees at idle.
Old Jun 5, 2003 | 09:28 AM
Evil DOHC's Avatar
With a 90 lb injector for example you have to run 40 degrees or so to burn up the fuel. The bigger the injector the more timing you must run at idle to compensate.
EVIL
