car breaks up sparatically....
Old Jul 16, 2001 | 10:56 PM
PROFILE EK4's Avatar
New User
Default car breaks up sparatically....
i was out testing my car and a few funny things are happening.....
my car on wide open throttle and on a hard downshift, the car is breaking up....the vtec hesitates....sputters a bit...then pulls and then breaks up...kinda like im hittin an early rev limiter...at times it sputters then pulls...and sometimes it just kinda "revs out".....could it be from a. not high enough octane b. o rings in the vtec solenoid or oil pressure sensor messed up...
I have enough oil so i know oil pressure is not low, but the breakup is sparatic throughout the powerband...sometimes before vtec...sometimes during vtec...sometimes at the top of a gear....
Im currently running about 12 5 compression on 93 octane with octane booster....
if anyone knows about this problem please help me out...
oh and please no off topic posts on this one...
Old Jul 17, 2001 | 04:19 AM
eg6ajk's Avatar
Default Re: car breaks up sparatically.... (eglover)
did you try adjusting the mixture either with FPR or Apex or Fields controller....
you might be running rich or very lean.....any signs off overheating or detonation....
Old Jul 17, 2001 | 07:34 AM
PROFILES2000's Avatar
TTT
Old Jul 17, 2001 | 07:57 AM
Evil DOHC's Avatar
Default Re: car breaks up sparatically.... (Y2kGsR)
Run a range colder plug because of the high compression. Also, check your ignition timing as well as cam timing.
Those three things should definetly solve your problem.
EVIL
Old Jul 17, 2001 | 11:22 AM
newspeedR's Avatar
Default Re: car breaks up sparatically.... (Evil GS-R)
Try using at least 6 heat range plugs... should solve the ping
SuperBowser707
Sep 3, 2012 08:31 AM
em1gangsta
18
Jun 10, 2008 09:37 AM
EkPandaGSR
Sep 19, 2004 09:30 AM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
NSX Bob
Apr 13, 2002 04:10 PM
