hybrid help - which entire stock exhaust bolts up to a b16 in 92 hatch?
Old Jun 3, 2003 | 12:53 AM
stripes777's Avatar
Default hybrid help - which entire stock exhaust bolts up to a b16 in 92 hatch?
the piping on my car is a bit rigged and welded. im wondering which components of the exhaust system i need, in order for it to bolt on perfectly.
of course ill use a b16 header, would i then need the cat conv. off of a 92-95 hatchback? what about the rest of the piping? thanks alot
Old Jun 5, 2003 | 12:11 AM
stripes777's Avatar
Old Jun 5, 2003 | 12:15 AM
JustLooking's Avatar
Default Re: hybrid help - which entire stock exhaust bolts up to a b16 in 92 hatch? (stripes777)
Hi,
This goes for all B series motor in a EG HB. Use the catback and cat off a stock dx or si and everything will bolt up. CX or VX piping will not work.
Old Jun 5, 2003 | 12:24 AM
_BEN_'s Avatar
Default Re: (stripes777)
Well the logical response would be the stock exhaust from a eg4(Vti) or eg6(SiR) plus cat. Is there a state side umm ?EH? that has a sohc vtec motor? That should be similar to the vti's pipes sence it is sohc. When I swapped the exhaust on a friends eg4 I noticed that his was the same as my stock pipes.
It would probably be cheaper just to get some aftermarket exhaust than buying oem new.
Old Jun 5, 2003 | 02:35 AM
stripes777's Avatar
thanks for the responses, the most important was the cat conv. , now i know which one to get. my car is currently running a custom pipe form the headers. now ill just go pick up a 92-95 dx cat and rework the custom piping, thanks alot guys.
coletrain_eg
Jun 17, 2011 08:18 AM
Ron454321
Feb 16, 2007 06:36 AM
watsvtecEK
Apr 30, 2006 01:04 AM
SkoundrelUSA
12
Sep 26, 2004 07:33 AM
EGhatched
Mar 13, 2004 08:48 AM
