Getting engine codes (Everything is wrong with this car!!!)
Old Jun 2, 2003 | 09:54 PM
KooK's Avatar
Mustang Sally
Default Getting engine codes (Everything is wrong with this car!!!)
Ok, the floor is blinking at me, blinks 6 times, stops, then blinks 10 times... Whats it trying to tell me?
Thanks!!
Old Jun 2, 2003 | 09:56 PM
bossman032's Avatar
Default Re: Getting engine codes (KooK)
what engine what car..?
Old Jun 2, 2003 | 10:03 PM
skud_dusty's Avatar
Default Re: Getting engine codes (bossman032)
this is for the MPFI (Si) cars, but might help a little possibly...they might not be the same codes, but hope it helps a little
OBD 0 PM6 Ecu codes:
0 - ECU
1 - Oxygen Content
3 - Map sensor
5 - Map sensor
4 - Crank Angle
6 - Coolant Temperature
7 - Throttle Angle
8 - TDC Position
9 - No. 1 Cylinder Position (1.6)
10 - Intake Air Temperature
12 - Exhaust Gas Recirculation System (1.5 CAL:A/T)
13 - Atomospheric Pressure
14 - Electronic Air Control
15 - Ignition Output Signal
16 - Fuel Injector
17 - Vehicle Speed Sensor
19 - Lockup Control Solenoid Valve (A/T)
20 - Electric Load
Old Jun 2, 2003 | 10:07 PM
KooK's Avatar
Mustang Sally
Default Re: Getting engine codes (skud_dusty)
The number 6 one makes since because the guy that sold me the car with a blown headgasket told me the engine got REALLY hot and smokey...
The number 10 one might be because I have a ghetto short ram intake...
Ok, thanks
By the way, my car is in my sig with the stock engine, well, D15B2, Civic DX, but all in all pretty much the same .
Thanks!
Now how do I reset it?
Old Jun 2, 2003 | 10:17 PM
RuthlessEF-9's Avatar
not really for the 10 check if that white sensor on your manifold is pluged in or if its still good
good luck
gnxpro24
45
Apr 22, 2011 07:12 AM
420aNT
Jun 5, 2003 09:23 PM
shorti
Jan 28, 2003 09:47 PM
LSVTEC408
Dec 10, 2002 04:22 PM
HonCiv
Nov 17, 2002 12:37 PM
