Si head
Old Jun 2, 2003 | 09:48 PM
PoweredByPrelude's Avatar
Default Si head
We're about to buy one for our B20. The guy is selling for 450...sounds high to me. Appox. how are these priced usually?
Old Jun 2, 2003 | 10:02 PM
4DeepCivic's Avatar
Default Re: Si head (PoweredByPrelude)
How complete is it? intake manifold, throttlebody.. etc.
Old Jun 2, 2003 | 10:08 PM
Default Re: Si head (4DeepCivic)
just the head, cams valves all that jazz bone stock.
Old Jun 3, 2003 | 07:06 PM
ttt
Old Jun 3, 2003 | 08:32 PM
EARLdaSQUIRREL's Avatar
official honda whore
well seeings how anymore you can get a complete b16 short block for 450 id say its a lil steep, i think i sold mine for 350 a cpl months ago
Old Jun 3, 2003 | 09:27 PM
Default Re: Si head (coptzer)
Oh well he allready bought it. Its an OBD0 Jdm Si head. Take a look at the pics and tell me if the cam wear is lookin ok. Very small scratches on them but doesn't look threatening.
Looks like someone allready tried a little porting on the #1
Modified by PoweredByPrelude at 6:47 AM 6/4/2003
Old Jun 3, 2003 | 09:30 PM
Dancing is Forbidden's Avatar
take off the .orig.jpg and i hope you are putting this on a OBD-0 car. otherwise plan on changing injectors and distributor
Old Jun 3, 2003 | 09:48 PM
Default Re: Si head (EF9_SiR)
Change the injectors and distributor to what? Will someone finally clarify which ecu to use also. I've been told an OBD1 GSR and also an OBD1 SI.
Old Jun 3, 2003 | 09:50 PM
IWearMyKswiss's Avatar
New User
chip a p28 ECU to run with your b20/vtec setup,...should have bought my head,...its machined for a frankenstein setup
Old Jun 3, 2003 | 09:54 PM
function83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoweredByPrelude &raquo;</TD></TR><TR><TD CLASS="quote">Change the injectors and distributor to what? Will someone finally clarify which ecu to use also. I've been told an OBD1 GSR and also an OBD1 SI. </TD></TR></TABLE>
obd 1 gsr, obd1 delsol b16 ecu, jdm b16/p30 ecu. oh and last but not least chipped p28 with dual cam specs.
and back to changing injectors and distributor. if it's going into an obd1 car make sure to use obd1 injectors and obd1 distributor (ex: gsr or delsol b16) and might as well swap out the manifold too for proper locations of sensors. example: skunk2 or type r.
if its an obd2 car use obd2 stuff.
Old Jun 3, 2003 | 09:57 PM
New User
Default Re: Si head (djhatch)
[QUOTE=djhatch]
obd 1 gsrQUOTE]
i thought the GSR ECU wouldnt work because of the secondaries or something like that ????
Old Jun 3, 2003 | 10:11 PM
Default Re: Si head (WiDeBoDyEK)
Sure thats not the OBD2 gsr your thinking of that wont work? And those cams look ok to everybody right
Old Jun 3, 2003 | 10:30 PM
function83's Avatar
i ran a b18c1 with a stock p72 without the secondaries wired.
i just ran em open, worked fine and didn't lose any performance.
no check engine lights.
Old Jun 4, 2003 | 07:51 PM
Well since the car is a 98 we're gonna use a Si ecu. How well will this match up with the jdm head. I was also thinking either to get an Si I/m or a skunk2 one. Will a gsr or type r I/M fit?
Old Jun 4, 2003 | 08:38 PM
ITRacer121's Avatar
hey John
bring the head over and I will match the ports with each other.
you can run a OBD2 GSr ECu (ecu I have sitting around) but the optimum will be a P28 chipped (you will need the jumper harness) to run the 99-00 ECU you will need a jumper as well
call me if you have anymore questions
Old Jun 4, 2003 | 09:38 PM
Default Re: Si head (ITRacer121)
Sup Anthony,
Hey we need to get this baby clean. Know anyone with a valve spring compressor? We have one at work but I don't know if it will work on this head. About the port matching Kev and I were thinking of having the thing ported and polished at Gene quicks he does some bad *** work. We still need to find out what pistons were gonna use with this head also. I don't think we want to high of compression either. And we need something with a larger valve releif for the vtec.
Modified by PoweredByPrelude at 6:52 AM 6/5/2003
Old Jun 4, 2003 | 10:10 PM
MPower332TI's Avatar
You cant use a 99-00 SI ecu in a 96-98 car. For some odd reason Honda decided to chage the whole dash harness between 98 and 99, so you cant swap an Si ecu in. If you wanna stay obd2 you need to get a GSR ecu or if you wanna spend big bucks get a type r ecu. I would recomend going obd1 and just getting a P28 chipped with the stock ITR program. Ericks racing can hook up the ITR program on the ecu and you should be able to find a P28 for cheap(92-95 civic ex). As far as injectors and dist it doesnt really matter. You can use an obd1 b16 dist or a obd2 b16 dist. The injectors can be whatever you want.
Old Jun 4, 2003 | 10:15 PM
Default Re: Si head (jDmDxTuRd)
Well if we go OBD1 how do we pass emissions?
Old Jun 4, 2003 | 10:29 PM
d0nkeyxPunch's Avatar
Banned
obd-1 is less restrictive. You could pass emissions illegally but at state ref, they look at EVERYTHING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoweredByPrelude &raquo;</TD></TR><TR><TD CLASS="quote">Well if we go OBD1 how do we pass emissions?</TD></TR></TABLE>
I dont know whats up with your emisions but where i live there are some countys that border mine that dont have emisions laws. So i just use a friends address or get a po box in that county. I dont know how it works where you are though.
Old Jun 4, 2003 | 11:14 PM
Well gsr ecu it is this car's gotta pass inspection.
Guess we'll take yours anthony. Oh and we may be switching the motor from your house to mine soon so we can do the piston work. I'll let you know ahead of time.
P12 EG6
Apr 3, 2010 01:57 PM
mCpai
Nov 18, 2009 12:54 PM
integraracing91
Jan 22, 2007 08:54 PM
Ewing8712
Aug 25, 2004 12:39 PM
Broken Gearbox
Apr 5, 2003 10:48 PM
