JDM CTR 5 lug the same as USDM ITR?
hi how are you doing fellas? was wondering if the JDM CTR 5 lug is the same as the USDM ITR 5 lug? I know both of them have a 32mm hub spline for the axles and the a arms are completely different but is the knuckles, brake components and everything else the same? I want to see bascially if I can put a JDM CTR 5lug brake conversion on a 93 civic? and if sowhat would I need to make it work?
Everything is the same except for what you mentioned. Basically, the A arms and the LCAs are different.
I had ITR 5 lug on my Ek, so it all works out.
The ebrake lines need a little bit of elbow grease to get into place, but it's not hard at all.
Uneekpinoysk8er
Dec 25, 2004 08:27 PM
jdmjohn02
Jan 12, 2004 12:03 AM
4doorturbo
19
Feb 17, 2003 10:36 AM
4doorturbo
Feb 16, 2003 04:51 PM
