ECU options...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noahk »</TD></TR><TR><TD CLASS="quote">The best way is to convert to obd1 and use the stock 94-95 b18c ecu. </TD></TR></TABLE>
yes dittot to that!
but if you don't want to convert over to OBD1 electronics you can always run a PR3 B16a1 JDM ecu, and just adjust the FPR up about 5psi'ish
yes dittot to that!
PR3 or PWO will be the cheepest DOHC v-tec ECUs. Can also go with OBD1 like about stated but this will require a OBD1 ECU, jumper harness, Diz, and a 4 wire 02 sensor
underdog_racer
Nov 11, 2007 08:52 PM
