Need Help..changing ATF fluid
Old Jun 2, 2003 | 02:04 PM
MyFirstPrelude's Avatar
Default Need Help..changing ATF fluid
1999 Accord Coupe EX V6
Where is the ATF oil fill plug?
I think it may be the brass color nut about an inch and a half away from the drain plug but it looks like it is at the same level as the drain plug. I checked my prelude's oil fill plug and it is at leat 3 inches up and to the left.
Since the one i think is almost at the same level I think it is pointless to start filling that one and everything comes out as I'm pouring. Please help.
Old Jun 2, 2003 | 02:13 PM
carolinaACCORD's Avatar
Default Re: Need Help..changing ATF fluid (MyFirstPrelude)
i know on the 4 cyl. you can fill throught the level check dipstick hole.
have never messed with the v6 though.
Old Jun 6, 2003 | 12:53 PM
Morad141's Avatar
Default Re: Need Help..changing ATF fluid (carolinaACCORD)
2000 Accord Coupe EX V6
1. Drain plug - On driver's side? I found a 3/8 square plug which I think is it.
2. Is the ATF capacity 6.2 pints? How much can I drain this way?
Found the Fill Plug - thanks Chiovnidca Even has ATF labeled on it
Can someone confirm the Drain Plug location? I'm 99% sure this is it, but want to be sure.
Modified by Morad141 at 2:11 PM 6/7/2003
Old Jun 6, 2003 | 01:34 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyFirstPrelude &raquo;</TD></TR><TR><TD CLASS="quote">1999 Accord Coupe EX V6
On the v6 it's on the top of the transmission. It's a 17mm hex plug below the air intake tube.
Old Jun 7, 2003 | 12:42 AM
fe519's Avatar
Default Re: Need Help..changing ATF fluid (Chiovnidca)
it says freakin ATF on the bolt itself man...
Old Jun 7, 2003 | 03:48 AM
Chiovnidca's Avatar
Default Re: Need Help..changing ATF fluid (fe519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fe519 &raquo;</TD></TR><TR><TD CLASS="quote">it says freakin ATF on the bolt itself man...</TD></TR></TABLE>
Does it? I never noticed. LOL
donnieb22000
18
Jun 26, 2018 10:20 PM
j0natell0
Feb 22, 2009 07:06 AM
jdmcivicracer89
Aug 2, 2007 03:32 PM
vics_si
Aug 4, 2005 04:47 PM
Mires
Sep 21, 2002 08:16 AM
