HP and RAM air intake
Old Jun 2, 2003 | 01:49 PM
TS 2JZ's Avatar
Default HP and RAM air intake
My freind has a 98 SH and just installed an AEM short ram intake, but the damn thing hisses like crazy and he is looseing lots of HP, does anyone know why this is?
Old Jun 2, 2003 | 03:55 PM
Final Flash's Avatar
Default Re: HP and RAM air intake (TS 2JZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TS 2JZ &raquo;</TD></TR><TR><TD CLASS="quote">My freind has a 98 SH and just installed an AEM short ram intake, but the damn thing hisses like crazy and he is looseing lots of HP, does anyone know why this is?</TD></TR></TABLE>
The noise from short ram or cold air intakes comes with the territory, it's just a fact, nothing you can do about it (except put the stock box back on). My CAI is loud as hell, but I got used to it.
As far as losing hp, what makes him/you think that, is this according to "butt-dyno" readings? If so, it may be all in his head. Did he reset his ECU after installing the short ram? He should have, if not that may be the problem...
Old Jun 3, 2003 | 11:27 AM
TS 2JZ's Avatar
Default Re: HP and RAM air intake (Final Flash)
I dont know if he adjsutetd the ecu but he did adjust the dyno, thx
Old Jun 3, 2003 | 11:47 AM
str8rcn's Avatar
Old Jun 3, 2003 | 11:49 AM
Behan's Avatar
Default Re: HP and RAM air intake (str8rcn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8rcn &raquo;</TD></TR><TR><TD CLASS="quote">?</TD></TR></TABLE>
maybe he adjusted his butt dyno.
Old Jun 3, 2003 | 01:07 PM
tonylude94's Avatar
"Did he reset his ECU after installing the short ram? He should have, if not that may be the problem... "
how can i reset the ecu without shorting anything? i have done I/H/E and haven't done this procedure, if this is proven to give better performance how can i do this? thanks in advanced...
Old Jun 3, 2003 | 03:49 PM
Default Re: HP and RAM air intake (tonylude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonylude94 &raquo;</TD></TR><TR><TD CLASS="quote">how can i reset the ecu without shorting anything? i have done I/H/E and haven't done this procedure, if this is proven to give better performance how can i do this? thanks in advanced...
I was told that you should reset your ecu after every bolt-on install. Instructions are here: https://honda-tech.com/zerothread?id=131182 The "SEARCH" button is your friend.
Old Jun 3, 2003 | 06:39 PM
TS 2JZ's Avatar
Its probly the ECU cause he hasent adjusted after the installation
Old Jun 3, 2003 | 07:38 PM
ophdehEEzY
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TS 2JZ &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if he adjsutetd the ecu but he did adjust the dyno, thx</TD></TR></TABLE>
he adjusted the dyno huh?!?!
serfenwaves
41
Sep 14, 2008 08:52 AM
iPaul05
Honda Civic (2001 - 2005)
41
Mar 24, 2007 03:52 PM
turbo boost
May 18, 2005 02:31 PM
japmarket1
May 10, 2005 04:56 PM
oMek
Aug 29, 2003 09:52 AM
