hf->si 'swap'
Old Jun 2, 2003 | 12:24 PM
Lo-Buck EF's Avatar
Default hf->si 'swap'
im doin some research for the hf/std to si swap (d16 no v-tec) as far as the wiring. does anyone know whats involved and what needs to be changed/added?
-spenc
Old Jun 2, 2003 | 12:34 PM
EF_LSVtec's Avatar
Default Re: hf->si 'swap' (SOLOef)
hf is already mpfi...to run vtec all you need is to add a couple of wires...vtec solenoid, 2nd O2, vtec oil pressure, knock sensor... http://www.hasport.com for more info.
Old Jun 2, 2003 | 12:51 PM
rioninja's Avatar
You just need the motor and ecu. Your distributor and harness will swap over to the SI.
Old Jun 2, 2003 | 12:53 PM
91civicDXdude's Avatar
HF and Si distributor is the same.
Old Jun 2, 2003 | 01:27 PM
Lo-Buck EF's Avatar
Default Re: (91civicDXdude)
ok, let me clarify:
ef hatch standard d15 to ef si d16 (no v-tec)
Old Jun 2, 2003 | 06:11 PM
Lo-Buck EF's Avatar
Default Re: (SOLOef)
the hasport page lists a harness for this conversion. is it necessary or can i use the si harnesses?
*bump for the retard
Old Jun 2, 2003 | 06:35 PM
Hondasaurs's Avatar
Use the HF harness on the Si engine. Problem solved.
Old Jun 3, 2003 | 06:20 AM
rioninja's Avatar
Default Re: hf->si 'swap' (rioninja)
Right. and in case you missed it the first time:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">You just need the motor and ecu. Your distributor and harness will swap over to the SI. </TD></TR></TABLE>
Old Jun 3, 2003 | 10:16 AM
Lo-Buck EF's Avatar
ok, i misunderstood. thanks everyone.
-spenc
Old Jun 3, 2003 | 10:24 AM
slowpokesi's Avatar
an hf isnt a std
std= DX
you either have an hf or a dx
if you have an hf, you can use the hf harness or the si harness, and the si ecu
if you have a dx you will need to convert to mpfi
peiku
Feb 21, 2006 03:10 PM
fullraceacura
May 24, 2005 09:49 AM
TeaminlineB16
Jan 5, 2005 05:48 AM
JSPECHB
Jul 16, 2003 07:31 AM
91HATCH
23
Oct 15, 2002 05:03 PM
