Does the distributor have any thing to do with Fuel delivery?
Old Jun 2, 2003 | 11:49 AM
civicspeed77's Avatar
Default Does the distributor have any thing to do with Fuel delivery?
Wondering if my distributor is part of my fuel problem?
Old Jun 2, 2003 | 12:37 PM
EF_LSVtec's Avatar
Default Re: Does the distributor have any thing to do with Fuel delivery? (civicspeed77)
what kind of problem are u having? to answer your question, No. Distributor has nothing to do with fuel delivery, but has a lot do do with how your car burns your fuel...Distributor=distributes spark to burn your fuel on each cylinder.
Old Jun 2, 2003 | 12:53 PM
4drEF's Avatar
Keyboard Humorist
Yes. The CYP sensor tells the ECU when to set off an injector.
Old Jun 2, 2003 | 01:10 PM
My ride starts up but then shuts off immediately. It will not hold gas. I tried checking spark on the wires. only two wires held spark. But I have new plugs and wires. Is it the dist.
Old Jun 2, 2003 | 01:41 PM
JonGP4's Avatar
Default Re: (civicspeed77)
so r u saying you have spark in only 2 cylinders? if thats the case, yeah something is wrong with your distributor not your fuel. But yes, the distributor tells the computer when to fire an injector.
Old Jun 2, 2003 | 01:56 PM
Default Re: (JonGP4)
No kidding it is my distributor...Dam that means a lot of pecos...I bet it is expensive right?
Old Jun 2, 2003 | 02:33 PM
rioninja's Avatar
Does the car run fine most of the time? If so and the car is throwing NO codes, and your sparking only a one or two of the plugs after it dies, then chances are its your ignitor.
Old Jun 2, 2003 | 02:40 PM
JonGP4's Avatar
Default Re: Does the distributor have any thing to do with Fuel delivery? (rioninja)
yeah used ones run about 100 bucks from the junkyard. what motor are you running? if its stock is it DPFI or MPFI? i have extra distributors for both. I'll do like 75 for one if you would like. Let me know.
Jon
Old Jun 2, 2003 | 03:38 PM
I have the sucky dual port....Yeah u have one for sale???
Old Jun 2, 2003 | 05:48 PM
hybridmoose's Avatar
You should try a new cap and rotor man. If your getting spark then that means your internals for the most part are working in the distributor. If all else fails then I would get a new one.
Old Jun 2, 2003 | 06:05 PM
rjardy's Avatar
Default Re: (hybridmoose)
try replacing the ignitor...
Rob
Old Jun 2, 2003 | 07:16 PM
JonGP4's Avatar
yeah i got one, 75 shipped. the ignitor (which is the common part the goes out runs 89 bucks at honda) so i'll send u the whole thing, cap rotor coil and dizzy for 75 if u want. let me know,
JonGP3@hotmail.com
Dan16z6
Jan 4, 2016 03:19 AM
catsman50
22
Jun 15, 2010 05:21 PM
integ_lude
10
Oct 1, 2007 04:02 AM
atli126
Oct 19, 2003 11:16 PM
junya16
Mar 13, 2003 09:14 PM
