Can I lower the boost w/ my internal wastegate?
Old Jun 2, 2003 | 08:55 AM
RedStarGsr's Avatar
Default Can I lower the boost w/ my internal wastegate?
im starting the buildup, and im going to be running a 14b (tdo5h). internal wastegate is set at 8psi, and eventually i will be running 8spi, but im considering starting out w/ 5psi just to play it safe, and make sure everything is running good.
Ive heard you can adjust the spring, but I will be installing the turbo, then running it for a while, then upping it to 8psi once 5psi isn't enough. im used to all n/a hondas, so im sure 5psi will be enough to float my boat, and safety is my number one concern. if i cut or get a different spring or lengthen the rod or whatever you do, ( i dont know! ) can i undo it or do a different a spring when the turbo is in the car? i really appreciate your help.
probobly will be running a tinker219 SS log style manifold, 14b, 1g dsm bov, boost code ecu chip, dsm450s, and the likes...thanks for everyone's help.
oh yea...its on a 9.6-9.7c/r b17 w/ 120xxx.
Old Jun 2, 2003 | 09:10 AM
InTeGrA B18b1's Avatar
Default Re: Can I lower the boost w/ my internal wastegate? (RedStarGsr)
search..........i think you can adjust something on the actuator or something
Old Jun 2, 2003 | 09:14 AM
KurumaTuning's Avatar
Default Re: Can I lower the boost w/ my internal wastegate? (InTeGrA B18b1)
adjust your internal w/g rod in.....
Old Jun 2, 2003 | 09:24 AM
RedStarGsr's Avatar
how the hell do i adjust the rod in?
Old Jun 2, 2003 | 11:34 AM
Infinity_Racer's Avatar
Default Re: (RedStarGsr)
the end of the rod/arm that is connected to the exhaust side of the turbo can be adjusted by screwing it in or out...its hard to explain...just look at your turbo and wg and you'll know what we mean...
Old Jun 2, 2003 | 12:46 PM
delslow94's Avatar
dan they are talking about adjustable wastegate actuator arms. i doubt yours has a threaded arm on it with two nuts to lock it. look at it when u get a chance or send me some pics and ill tell u if u can with urs. i know you can always thread it and make it adjustable but its always good to check first to see if you already have it. look up about grand national turbo's they have the adjustability to their turbo's from the factory.
Old Jun 2, 2003 | 12:50 PM
Dublocivic's Avatar
Default Re: Can I lower the boost w/ my internal wastegate? (delslow94)
Or you could make/buy a Joe p manual boost controller for dirt cheap... works like a charm.
http://www.joepmbc.com/
Old Jun 2, 2003 | 05:41 PM
RedStarGsr's Avatar
bump
Old Jun 2, 2003 | 05:47 PM
technine's Avatar
Default Re: Can I lower the boost w/ my internal wastegate? (Dublocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dublocivic &raquo;</TD></TR><TR><TD CLASS="quote">Or you could make/buy a Joe p manual boost controller for dirt cheap... works like a charm.
http://www.joepmbc.com/</TD></TR></TABLE>
You can't lower boost with that, only increase... right?
Old Jun 3, 2003 | 07:58 PM
RedStarGsr's Avatar
thats what i ghought..only increase, not lower..
odishaw
Apr 1, 2008 04:37 AM
sohc_turd
May 20, 2007 07:24 PM
SilverCoupeEj8
Jan 15, 2007 09:22 AM
ragethemachine86
Aug 14, 2006 01:25 PM
PIC Performance
Jan 24, 2006 08:58 PM
