Sh*t 1/4 Mile Times - Any Help Appreciated...
Old Jun 2, 2003 | 07:59 AM
T-Blaze's Avatar
Default Sh*t 1/4 Mile Times - Any Help Appreciated...
Hi Guys... I went to the track yesterday and got some real crap times...
The best I got was...
reaction - 1.024
60 ft - 2.469
330 ft - 6.588
1/8 ET - 9.807
MPH - 78.46
3/16 ET - 12.449
1/4 ET - 14.831
MPH - 98.46
I thought this was rubbish. My Set up;
Del Sol B16A2, Max Rev Mani, 2.5" Down pipe, T3/TO4e 57 trim 48 ar, Standard (2.25") Zorst, 425cc injectors, VAFC. I'm putting down about 215 WHP @ around 8.5psi with 192 TQ.... Stock Tyres
I know I need to practice more with the launches but I was thinking any help in the setup would be appreciated...
TIA.
Old Jun 2, 2003 | 08:34 AM
drewspeed's Avatar
Default Re: Sh*t 1/4 Mile Times - Any Help Appreciated... (T-Blaze)
Any FWD FI setup is going to have traction problems. Your 60ft time can be worked on/solved with some better tires. Then don't know how good of a driver you are but with that MPH you should be doing mid-high 13's soon enough
Good luck
Old Jun 2, 2003 | 08:35 AM
T-sohctec's Avatar
Traction anyone?
Old Jun 2, 2003 | 08:38 AM
RedStarGsr's Avatar
Default Re: Sh*t 1/4 Mile Times - Any Help Appreciated... (T-sohctec)
hmm...work on launches-- im sure its hard to launch a FI fwd car, but just speakin from experience my n/a setup was running a 2.3 60ft, and a 14.701@95mph... I really don't know how to help, but im interested in seing what others will say to help you out. GOOD LUCK....my best advice (and probobly everyone elses) will be just keep practicing, get as many runs in as you can.
ps: my friend just weighed his del sol dohc vtec w/ him in it, and it was a hair under 3000.
Old Jun 2, 2003 | 09:12 AM
InTeGrA B18b1's Avatar
Default Re: Sh*t 1/4 Mile Times - Any Help Appreciated... (RedStarGsr)
we need info like what rpm you launched at and whens your full boost at?
Old Jun 2, 2003 | 10:46 AM
madman604's Avatar
Default Re: Sh*t 1/4 Mile Times - Any Help Appreciated... (InTeGrA B18b1)
with 215 hp you should be 14 flat or into 13's. you need to work on your driving/launce technique.
Old Jun 3, 2003 | 12:15 AM
T-Blaze's Avatar
Hey Thanx for the info guys...
I was launching at 4k revs - 4.5k revs just so as I wouldn't lose too much traction. I get full boost at around 4.5k - This used to be a lot lower but since I turned the boost up a little it is definately higher...
Old Jun 3, 2003 | 03:57 AM
SiR Kid's Avatar
New User
Default Re: (T-Blaze)
Are you spinning through second? Try shifting SLOWLY to second, and let the turbo spool back up again once it's in second. This will not shock the tires, and keep the front end planted. You might lose a MPH or 2, but the traction should pull the car through the traps .2-.4 seconds faster.
I went 13.8 @102 with 232 HP at the wheels, 180 torque, on POS 185/65/14 all season tires off a 96 Civic LX! I'm sure you'll see some better times if/when you just practice!
Good Luck!
Old Jun 3, 2003 | 04:10 AM
trbob16a's Avatar
Default Re: (SiR Kid)
del sol, the mysterious never go fast car
Old Jun 3, 2003 | 04:24 AM
SiR-DC2's Avatar
Default Re: (trbob16a)
Not trying to flame but is that dyno hp or guessing? looks like too much tourqe from a B16A w/ only 8.5 lbs boost, anywho, you're 60' isn't that great, get some stickier tire, every .1 you can shave off your 60' you'll just about shave .2 off your 1/4 mile et.
swlabhot's Avatar
Put sum BIG PHAT slicks on and launch the crap outta her!!
Old Jun 3, 2003 | 06:19 AM
T-Blaze's Avatar
Default Re: (SiR-DC2)
That's Dynoed.. @ 192 TQ...
Steve - What da dilly wiv da kit??? Has she arrived??? U up 4 G X 2nite??
Old Jun 3, 2003 | 07:09 AM
Honda4CX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr &raquo;</TD></TR><TR><TD CLASS="quote">hmm...work on launches-- im sure its hard to launch a FI fwd car, but just speakin from experience my n/a setup was running a 2.3 60ft, and a 14.701@95mph... I really don't know how to help, but im interested in seing what others will say to help you out. GOOD LUCK....my best advice (and probobly everyone elses) will be just keep practicing, get as many runs in as you can.
ps: my friend just weighed his del sol dohc vtec w/ him in it, and it was a hair under 3000.</TD></TR></TABLE>
I too was spinning on 1st & 2nd, tried dumping around 2.5K, 3K & 3.5K on street tires.
Newly installed MaxRev kit onto a B18B hatch, running stock 6.5-Psi.
I ran: 14.41 "untuned" @ 99mph & 2.27 60-Foot (r/t was, uh, duh 1.306 was sick as a dog "my excuse" )
But ....
Modified by Honda4CX-T at 1:44 PM 6/3/2003
Old Jun 3, 2003 | 07:19 AM
T-Blaze's Avatar
Damn - 2.27 is a good 60 ft (well compared to mine anyway?? I just gotta keep on trying... ALong wiv some more mods...
Old Jun 3, 2003 | 07:59 AM
racinskittle's Avatar
How much does your friend weigh? (no offense but that seems like a lot)
Old Jun 3, 2003 | 09:16 AM
ReVtecSi's Avatar
your reaction needs some work, along with your traction. stock tires on a del sol? are they OEM from when they car was purchased?!?
riceball777
Aug 2, 2005 05:46 PM
jasb16A2aSIR2
Apr 19, 2005 05:24 PM
cornhusker
Apr 7, 2004 07:29 PM
B.
46
Jul 5, 2003 09:39 PM
T-Blaze
Jun 3, 2003 12:20 AM
