help fast !!!!!!
ok i just lowered my car now i tried to get a jack under it today and no go, i have to change my oil tomorrow and i can't get my car off the ground. what do you guys do?
either buy a low profile jack or buy some ramps.
ghetto way is to get some wood and lay it down on the ground drive up on the wood and jack it up that way. Make sure you keep the wood under when u lower it or you won't be able to get the jack out.
i thought about doing the wood thing but was not sure if there was not any craftier idea the wood will work tomorrow. Where can i find a low profile jack?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">2x4 works wonders for me</TD></TR></TABLE>
meaning: drive your car onto some 2x4's before you try to jack it up.
Im thinking your trying to get your floor jack under there and if thats the case just try raising it up a little with your stock twisty jack & then slide the bigger one under
when I had my accord it was pretty low and I dont know how low you car is but if there is another person there just grab the wheel well and pull up while the other person slides the jack in and if there is not another person 2x4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaKesDaGuRLsWeTT »</TD></TR><TR><TD CLASS="quote">Im thinking your trying to get your floor jack under there and if thats the case just try raising it up a little with your stock twisty jack & then slide the bigger one under</TD></TR></TABLE>
thats what i have to do...its a pain in the *** though, because i don't have a floor jack, just a scissor and jack stands, so i can only get one side up at a time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAM JSJ »</TD></TR><TR><TD CLASS="quote">drive over some woods or have friends lift from the fenders or use a stock floor jack
= bent fenders.
Just use wood or bricks.
</TD></TR></TABLE>= bent fenders.
ditto, I gotta do this and my car isn't even that low...
Bigjon, shorter ramps especially made for lower cars, not the taller ones that you're thinking of
FrederickRighteous
17
Jun 17, 2008 12:56 AM
Stinkycheezmonky
Apr 7, 2004 07:38 PM
