Turboing an R questions ........
What kit did you use, is Drag III one of the better ones?
Did you replace the head gasket to lower compression, and with what kind if you did?
How'd you tap in the oil lines into the oil pan?
Anyone do a before and after dyno?
Did you upgrade the clutch with it, and if so which one?
Did you add a turbo timer and/or electronic boost control, or not?
Sorry about all the questions, but I'm trying to help someone get a package together, and he wants to do it right the first time!
