the strangest thing with this frek'n light...
Ok, I've solved many wiring problems with various ECU but here, I'm dealing with a freak'n dome light.
The switch works fine. Pushing it manually kills the dome light, BUT when I close the door, the light goes off for split second and when the door is fully closed it comes back ON arrrrrrrhhhh
any ideas?
any ideas?
From: I told you to wait in the truck in Texas, United States
from the factory there is a small black rubber cover on the end of the switch,
if it falls off the light will come on sometimes...
I have a vacuum cap on one of mine..
dome light is the simplest of wiring available.
hot and a ground. :> when grounded its on. when not its off.
the lil switch u see in the pic jus grounds when pushed in. and is really frail. so jus find a junk yard one. or rig it.
mine isnt there on the drivers side. its always grounded. only the passengers side makes the light go off and on. i also made the hood work together with the dome light. as i was havin hood latch problems for a couple weeks.
