Cleaning up motor after spraying a chemical on it...
Old Jul 16, 2001 | 10:41 AM
White Dragon's Avatar
Default Cleaning up motor after spraying a chemical on it...
You know when you spray a chemical on the motor - like a degreaser- and then it leaves the motor with a film where it looks kinda corroded and not shiny... Is there ANY way to get rid of that and get it to look new again?
Old Jul 16, 2001 | 10:57 AM
J Ritt's Avatar
Default Re: Cleaning up motor after spraying a chemical on it... (White Dragon)
WD,
All you need to use is Dawn dish detergent!!! You don't need any harsh chemicals man.
Old Jul 16, 2001 | 11:02 AM
Default Re: Cleaning up motor after spraying a chemical on it... (J Ritt)
WD,
Yeah, I know. I don't use any chemicals (just car wash soap) on my engin bay. I bought a used car though, and aparently, they used some nasty chemical and I was just wondering if there was any way to get that 'like new' look back
Old Jul 16, 2001 | 11:07 AM
Digital-R's Avatar
K-Mart or Wal-Mart sell some engine detailer. Is supposed to be used after you use Engine Degreser. I think it is made by CD2.
Old Jul 16, 2001 | 12:46 PM
Jimmy L's Avatar
Default Re: Cleaning up motor after spraying a chemical on it... (Digital-R)
Try some simple green it works. Just spray down your cold engine with full strength simple green let it sit for a few minutes (more if it's really dirty) then hose it off. I've doe mine a few times and it still looks like new, no film. And not to sound like a tree hugger, but it is completely safe for the environment.
Old Jul 16, 2001 | 01:09 PM
eurodeseo's Avatar
Default Re: Cleaning up motor after spraying a chemical on it... (trouble)
...And not to sound like a tree hugger, but it is completely safe for the environment.
LOL...what's wrong w/ tree huggers?
Old Jul 16, 2001 | 01:20 PM
Big Phat R's Avatar
It's called engine finish - it's basically a high-temp clear coat spray - it works well but you have to make sure that everything is surgically-sterile clean or else you will have a crappy result.
I would remove as much as you feel comfortable from the engine bay and clean parts individually. Having an air hose helps - so you can blow away standing water and water that gets stuck in nooks and crannies.
New wires/hoses are your only hope for restoring any of the old looking rubber pieces...
mynameizstitch
Feb 11, 2010 05:41 PM
25Type-s
Nov 30, 2006 10:13 PM
quickls
Oct 14, 2003 07:18 AM
Blue10karat
Jun 5, 2003 08:26 PM
AllMotorITR
Sep 25, 2002 05:48 PM
