piston ring questions!!!
Old Jun 1, 2003 | 07:44 AM
BlendedEJ8's Avatar
Default piston ring questions!!!
what is the offest of OEM piston rings for a d16a6??? please help me!!!!!
Old Jun 1, 2003 | 07:45 AM
BlendedEJ8's Avatar
Default Re: piston ring questions!!! (CRXSi_AutoX)
ok. i found out it is either..... OS 0.25 or OS 0.50
anyone know which one?
Old Jun 1, 2003 | 07:54 AM
PhatOptimo's Avatar
The D16a6 can be bored over twice. You go .25 over first then .50. You can do either but most people who want thieir motor to last another oversize will go .25 first. You can go as high as .50. To answer you question it is both.
Old Jun 1, 2003 | 05:52 PM
BlendedEJ8's Avatar
Default Re: piston ring questions!!! (Phat_Optimo)
okay. that kinda answers my questions but not all the way..... my piston rings are fried so i need to buy new ones. i dont know if the stock offset is .25 or .50
Old Jun 1, 2003 | 05:55 PM
H22CRX's Avatar
I'd almost guarantee that they are .25, even aftermarket pistons usually give you those rings unless you ask for bigger ones. Being that's your motor, I'd say .25.
Old Jun 1, 2003 | 06:06 PM
PhatOptimo's Avatar
Default Re: piston ring questions!!! (H22CRX)
I the pistons are the ones that came with the motor from the factory then they are std. (standard). Meaning the pistons from the factory are std. I a pretty certain about this.
Modified by Phat_Optimo at 11:04 PM 6/1/2003
Old Jun 2, 2003 | 02:32 PM
BlendedEJ8's Avatar
ok. well, if i were to replace my piston rings, would i have to get my cylinder honed?
Old Jun 2, 2003 | 08:13 PM
H22CRX's Avatar
You only need to hone the cylinders if the crosshatch on the walls are gone. So basically you need to have someone look at it and let you know what they think.
TypeRMOBBiN209
41
Jan 19, 2011 11:57 AM
gorillahumper
Jan 17, 2011 09:38 AM
EKJOE
15
Mar 31, 2009 07:42 PM
DC4 Rasta
Jan 5, 2007 06:44 PM
da_rimrocka
Nov 30, 2005 12:14 PM
