Will it work?
Ok, someone wants to sell me Type R pistons for my DOHC ZC. Should give me like 12:1 Compression. What do i have to do to get B-series pistons to work in my D-Series block, and how much $$ am i looking at to spend? Also what rods should I get? The ones for a B-series or the ones for a D-series?(Im wanting Eagle Rods). Thanks!
i think you will have to bore out the block as the type r block has like 81mm bore or something and the a6 has like a 75mm, i think its too much of an over bore for the block to handle. im not sure on this though.
edit, ya what he said!
i believe the max bore on a d series engine is 80mm, i have heard of 81mm though not confirmed.
Modified by tek_civic at 9:47 AM 6/1/2003
u could talk to some machine shops and see if they can bore ur cylinders..if the cost, replacement ratio is low..then go for it if u dont need transportation for a couple of weeks
determine the cost..not much is impossible with enough money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepnite »</TD></TR><TR><TD CLASS="quote">u could talk to some machine shops and see if they can bore ur cylinders..if the cost, replacement ratio is low..then go for it if u dont need transportation for a couple of weeks
good point, money buys everything that can be bought, and more. lol. while your at it get a stroker kit and make some more displacement, talk to the guys at RSmachines.com they do a lot of the stuff your asking.
</TD></TR></TABLE>good point, money buys everything that can be bought, and more. lol. while your at it get a stroker kit and make some more displacement, talk to the guys at RSmachines.com they do a lot of the stuff your asking.
Well as far as I know it's impossible to go 6mm over in bore because you'd have no cylinder walls left.
The B series guys have to get completely new drop-in sleevs to go from 81mm bore to 85mm more (if I'm not mistaken) so again, I don't think it will work.
Let's just suppose for one second that it could work though - I'm sure the wrist pin location will still negate any thoughts of actually putting ITR pistons into a D block.
Why not just buy some good forged higher CR JE pistons?
If it's even possible (though I don't think so at all) to put ITR pistons in a D block, the cost to do so would make it a damn silly idea.
How much money are you trying to dump into that ZC?
JE pistons : search google
Wiseco pistons: Import Builders - http://www.importbuilders.com
Try those first.
Try those first.
