Valve Nut Size
Old Jun 1, 2003 | 01:44 AM
fe519's Avatar
Default Valve Nut Size
just a quick question... I got a 96 Accord LX, what is the valve nut size on it so I can adjust the valves? Thanks
Old Jun 1, 2003 | 03:56 PM
aengnr1's Avatar
Default Re: Valve Nut Size (fe519)
10mm
Old Jun 1, 2003 | 10:34 PM
SOHCMAN's Avatar
Default Re: Valve Nut Size (aengnr1)
just adjusted mine twice in the past week... (too much valve noise 1st time becaue I put them at .013) Now thay are a nice .009 ish
But ya, all you need is a 10mm box end wrench, and a screwdriver, plus a 10mm ratched for the cover, and a torque wrench to put it back on (86 in lbs)
peace, sohc
Old Jun 2, 2003 | 11:17 AM
fe519's Avatar
Default Re: Valve Nut Size (SOHCMAN)
can you give me some idea where i can find a tool to adjust it rather than the stupid snap on one that cost a fortune. what do you guys use?
Old Jun 2, 2003 | 12:47 PM
GimpyAccord's Avatar
Honda does make a special tool for this aswell... unfortunatly I don't have the tool# handy. Irs pricey though too and I mean... I personally never have trouble using a boxend / flat head on these SOHC engines. If I had a DOHC engine I might consider the tool as it gets a lil harder to hold the feeler.
Old Oct 23, 2015 | 02:46 PM
jstmeseg's Avatar
Icon3 Re: Valve Nut Size
It is a 10mm soze. The tollthat you can get is a 10mm jam nut vlve adjustment tool. They are pretty expensive but you can find them on ebay and amazon for about 12 to 15 dollars. just makes it more efficiaent but using a 10mm wrench an da screw driver is good too.
Amazon.com: 10mm Honda Jam Nut Valve Adjustment Tool: Automotive Amazon.com: 10mm Honda Jam Nut Valve Adjustment Tool: Automotive
RUBZERK
Feb 17, 2004 12:46 PM
photonjedi808
May 23, 2003 12:46 PM
Jamison
Mar 16, 2002 02:17 PM
b18bvudoo
Dec 21, 2001 03:20 AM
Drag_Dc2
Aug 6, 2001 12:46 PM
