Be sure to check your tire pressures...
Old Jul 16, 2001 | 08:58 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Be sure to check your tire pressures...
I don't know if this is Tech enough to stay here but be sure to check your tire pressures. I'm not sure what the recommended interval shoud be though. Reason being is that, although it's a common sense thing you should be doing, if you're like me, you get lazy and put it off. This is just a reminder to do it. My tire pressures were off about 4-5 lbs in the fronts and about 3-4 in the rears after not checking them for several months. My handling is back to par and my tire wear will probably be a bit more even now.
Also, don't waste your money on those pen-style tire pressure gauges! Get a good dial gauge with the air release valve on it. They're more expensive but they are more accurate.
Old Jul 16, 2001 | 09:04 AM
indy's Avatar
Default Re: Be sure to check your tire pressures... (Gee3)
I just checked my tire pressure yesterday since I had to fix a nail in one of my tires. My fronts are set to 33 and rear are 35.
In fact, my tire presssures were all WRONG! The fronts were 39 and 34.
Back were 34 and 8!!!
Yes 8 cause thats the one with the nail in it!!!
Its all good now and I feel relieved....
Indy
PS- I used a digital gauge...those are awesome...
[Modified by indy, 10:05 AM 7/16/2001]
red97gsr's Avatar
I'm so **** that I check my air pressure every 2 weeks!
Old Jul 16, 2001 | 10:53 AM
96IntegraLS4DR's Avatar
When was the last time you check air pressure on your spare tire ?
Old Jul 16, 2001 | 11:41 AM
Gee3's Avatar
Default Re: Be sure to check your tire pressures... (96IntegraLS4DR)
What spare tire? hehe! The last time I checked the spare was about... hhhmmm... never! I guess I'll do that tonight! Thanks for reminding me!
Old Jul 16, 2001 | 11:48 AM
MintyDip's Avatar
What tire pressure should i use on my 205/50/15 potenza re730?
Old Jul 16, 2001 | 12:34 PM
Gee3's Avatar
Default Re: Be sure to check your tire pressures... (MintyDip)
I am experimenting with 35 front and 33 rears with my SP5k's. No real reason, but I am trying different combo's. Prior to that I had 35frt, 35 rears, that I used at the road track. I also had my koni's set at almost full, but it was a bit too harsh for the streets.
Old Jul 16, 2001 | 01:08 PM
berkel's Avatar
Good points G.
Since I have no PS, I run about 40-42 in the front and 40 in the rear on my Dunlop SP 9000.
This makes the wheel easier to turn and gets me better mileage...
Take care,
FB
Old Jul 16, 2001 | 06:32 PM
bmduncan's Avatar
New User
I'm trying to feel out the best pressure in my RE730s too. I think VtecOnly says to run them a little light (1-2 psi) of stock if I'm not mistaken. Currently running stock pressure 35f/33r with 700 mi. on the tires. Hopefully some of the other re730 owners will chime in.
Old Jul 16, 2001 | 06:53 PM
Dirt's Avatar
Great topic. Here's my input and a question. I check my pressures once a month and try to keep my 15k mile Kumho 712's at 35F/33R. But I still hear some serious squeal during hard street cornering. Do I need to add more pressure or get a more serious summer tire? My next tire will be the Toyo Proxes T1-S which should add even more grip than my current 712's during the warm months.
Gary, how is your CTR cam setup doing? After my A'PEXi V-AFC install my VTEC engagement is at 5100-5400 rpm ( I change it up occasionally) , and the power gain feels great (butt dyno). Thanks!
Old Jul 16, 2001 | 07:46 PM
G_S_R's Avatar
Default Re: Be sure to check your tire pressures... (Teken)
I too have RE730s. I use 35f/33r daily driving. AutoX I set 42f/38r. this has worked for me. I always check my tire pressures after every run, sometimes every other.
Old Jul 16, 2001 | 08:36 PM
Integ Grl's Avatar
Default Re: Be sure to check your tire pressures... (G_S_R)
Thanks for the reminder Gary! I've been slacking off a little too, but I decided to check them today since one of the tires looked a little low on air; turns out it was. I also didn't know the pen-style gauges were inaccurate. I figured, I should be fine as long as I use the same gauge in order to keep the readings consistant. I guess that just means the readings have been consistantly off!
Old Jul 16, 2001 | 08:42 PM
red97gsr's Avatar
Default Re: Be sure to check your tire pressures... (MmmVTEC)
I run mine at 40f/37r on my 215/40R16 ToyoT1-Plus tires (old model of the T1-S).
Old Jul 16, 2001 | 08:44 PM
red97gsr's Avatar
One other thing to keep in mind when checking tire pressure, I noticed that for my car, the side of the car that has been sitting the sun for awhile is always 1psi higher.
Old Jul 17, 2001 | 08:35 AM
Gee3's Avatar
Default Re: Be sure to check your tire pressures... (Integ_GrL)
Aaron - The CTR cam is doing good! I got it tuned and am happy with the results. I lost some top-end but I have a lot more lower midrange and lower end grunt, which works for me for road racing. The tuner had set the VAFC X-over at 4900rpm on mine.
Marsh - It's the Gary-Lube online reminder! hehe! I actually still have the pen-style gauge and i have to take a few readings to see if I get a consistent reading. So, like you, I am consistently getting the wrong readings too! I still need to buy a good dial gauge soon. (Man, I need to start my new job so I can get some $$ in my pocket!)
Old Jul 18, 2001 | 02:33 PM
MintyDip's Avatar
Thx for the reminder, finally found my tire pressure gauge.
just checked it right now, and its horrible
My 205/50/15 re730 are currently at
Front 32 and 31
rear 32 and 34
thx for the reminder, my pressure is horrible.
I think i'll try 35F/33R as u guys
Old Jul 19, 2001 | 12:37 AM
Caffeine Slug's Avatar
If all of you who hadn't checked your tire pressures in a while would just autocross [at least] once a month, you wouldn't have to worry about it so much!
For a decent pressure gauge at a good price, I suggest this one: http://www.racerpartswholesale.com/tirega.htm. Go for the "Racer's Special" at about $30.
MmmVTEC, I find that I get the best handling out of my 712's at about 44/40 front/rear. For the street I usually run around 35/33, however.
globy123
13
May 20, 2009 05:53 PM
John 07
Mar 23, 2009 07:47 PM
old_school_dohcvtec
Aug 27, 2007 12:39 PM
97dxnut
Apr 26, 2004 06:54 PM
TypeR1558
Aug 11, 2001 11:58 PM
