Neon install on an RSX
Old May 31, 2003 | 09:02 PM
Briman2021's Avatar
Default Neon install on an RSX
I just ahd a few questions about how to install a neon kit on an RSX.
1.)Where should I run the wire through the firewall?
2.)What would be the best way to protect the wires from the heat of the exhaust where they pass within just a few inches of it?? Should I use header wrap on the Exhaust pipe, or should I wrap the wires in aluminum foil or something like that?
Thanks!!
Old May 31, 2003 | 09:03 PM
slowman's Avatar
I took way too long
Default Re: Neon install on an RSX (Briman2021)
Ohh boy.
:Runs to get out of the way:
Old May 31, 2003 | 09:06 PM
Briman2021's Avatar
Default Re: Neon install on an RSX (slowman si)
well, actually its not for me.
My friend who is kind of a ricer, is leasing an RSX and got a neon kit for like $40, so he wants me to put it on.
here is my link ot the original thread that explains why im posting here...
https://honda-tech.com/zerothread?id=519847
Old May 31, 2003 | 09:09 PM
slowman's Avatar
I took way too long
Ohhh ok, sorry
Old May 31, 2003 | 09:15 PM
JustinL's Avatar
i dont know about rsx's but my friends escort and my civic have holes in the upper driver side aprt of the firewall that you can run wires through. and i wouldnt worry too much about the heat, maybe just alumnum foil and seal it real good. i havent had any problems
Old May 31, 2003 | 10:29 PM
importracer69's Avatar
post some pics when you are done with the install
Old May 31, 2003 | 11:41 PM
optikal_blitz's Avatar
two fassss....
two furrriuss.
I love it! let's see it when youre done, man.
Old May 31, 2003 | 11:51 PM
MPower332TI's Avatar
Default Re: (NatakuBlitz)
Whats the point to this product again???? Thanks for any info.
Old Jun 1, 2003 | 06:00 AM
Briman2021's Avatar
Default Re: (jDmDxTuRd)
If you are trying to be funny, grow up, who cares what someone else does to their car.
If you are serious, the point is to make a glowing effect under your car, which some people think is cool. If you have seen the fast and the furious, the 3 civics that hijack the semis have the same color neon kit as my friends car, so that is what it will look like, hopefully....
Old Jun 1, 2003 | 06:52 AM
E-Rok's Avatar
EPIC TUNING
Default Re: (Briman2021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Briman2021 &raquo;</TD></TR><TR><TD CLASS="quote">If you are trying to be funny, grow up, who cares what someone else does to their car.
If you are serious, the point is to make a glowing effect under your car, which some people think is cool. If you have seen the fast and the furious, the 3 civics that hijack the semis have the same color neon kit as my friends car, so that is what it will look like, hopefully.... </TD></TR></TABLE>
thats exactly what it will look like.....gay.
Old Jun 1, 2003 | 07:08 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: (rewsnaeht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">
thats exactly what it will look like.....gay.</TD></TR></TABLE>
very educated. If you can't help him, shut your moulth. and the rsx has a bunge on the drivers side firewall.. run the wires, won't worry about heat think will be fine.
Also try a trcik switchplate, maybe something in the glovebox/armrest flush mount on the roof.. anything can look nice as long as it looks like you took the time to do it right, instead of post something like this kid just did.
Old Jun 1, 2003 | 06:41 PM
hagrid's Avatar
Default Re: (menkio)
exactly, no one really gives a **** if you think its gey or to fass and to furioussss. its not your car plain and simple. and for the install, like he said, you shouldn't really have any problem with it getting too hot, and do not wire it stright to the battery. good luck. it'll be $50 well earned.
Old Jun 1, 2003 | 07:22 PM
Briman2021's Avatar
Default Re: (sang)
Why shouldn't I wire it to the battery, b/c on the diagram that came with the neon, it shows connections like this
1) Battey + to switch
2.)Switch to transformer
3.)Transformer to neon 1
4.)neon 1 to neon 2
5.) Neon 2 to neon 3
6.)neon 3 to neon 4
7.)neon 4 to transformer
Thanks for the help so far guys!!
Old Jun 1, 2003 | 09:29 PM
vain's Avatar
i think you would need it to come from battery to get enough current .. so cig lighter would definately NOT work. make sure you have an inline fuse too .. and as for as the diagram.. thats pretty much the way it should be done.
Old Jun 2, 2003 | 04:14 AM
Briman2021's Avatar
Default Re: (vain)
Yeah, it has a fuse, and it looks to be a pretty substantial looking thing. It is a little bit smaller than a spark plug I would estimate.
Thanks for the help!!
civicboy95
Jul 5, 2010 01:14 PM
CaliforniaK
Dec 16, 2007 01:04 PM
prostreetonline
Oct 20, 2003 07:34 PM
uNF$@#!
Jun 23, 2002 06:17 PM
