ABS light is on??????????
Old May 31, 2003 | 08:13 PM
accordhybrid's Avatar
Default ABS light is on??????????
I got an ABS light today and when I tried to jump the ecu and get the code the ABS light would go away so I don't really know what code I'm throwing does anyone have any ideas on how to get the code.
I know the jumper worked cause i have some CEL codes that flashed and so I know that it works.
Thanks
Accordhybrid
Old Jun 1, 2003 | 06:55 PM
4DRPIMPIN's Avatar
check your fluid in your abs pump, it might of started leaking, do you hear a humming noise when you first start the car then the humming stops then the abs light comes on?
Old Jun 1, 2003 | 09:10 PM
RotaryBzzzz's Avatar
Default Re: ABS light is on?????????? (accordhybrid)
check out the thread in my sig...
Old Jun 2, 2003 | 10:24 AM
joe_black's Avatar
Default Re: ABS light is on?????????? (RotaryBzzzz)
This is what my accord is doing too. My light comes on when I let the speed drop from 0-45mph and anything obove that it is okay? It also will interrupt my stereo sometimes? :? i thought i had it solved but it wasn't the case? I do hear the abs computer "clicking" is that a sign of the ecu going out? I tried pulling the abs relay after the car was started and it didn't check the pump and it seemed okay, but when i started it againg w/o the relay the light came on..?? I checked the cel but no code at all the light just went off... Is this a sign of a bad ABS module?
-Joe
Thx,
Joe
Old Jun 2, 2003 | 12:42 PM
Default Re: ABS light is on?????????? (joe_b)
The speed-problem sounds like a bad/going-bad wheel sensor to me. As well as the pump.
If you hearing it 'buzzing' at start-up, it's fluid level is low and/or it is probably going bad. What year car, trim level and mileage?
Modified by RotaryBzzzz at 10:07 PM 6/2/2003
Old Jun 2, 2003 | 01:17 PM
Thanks for the help but it turned out to just be a blown fuse under the dash.
Accordhybrid
Old Jun 2, 2003 | 02:37 PM
joe_black's Avatar
Yeah, it will pump up when i start it sometimes but
not all the time mostly once in the morning. I have a
1997 Honda Accord Ex Coupe.
Thanks
Joe
joenoreason
Apr 28, 2007 08:56 PM
LS1powered
Apr 27, 2006 09:13 PM
pearlteg
Jul 6, 2004 05:32 PM
vain
Oct 16, 2003 03:26 AM
