What should my fuel pressure be at, need an answer quickly!!!!
Old May 31, 2003 | 08:09 PM
DLOTYPER's Avatar
Default What should my fuel pressure be at, need an answer quickly!!!!
whats up, brief description of my setup, 98 gsr, DRAG 3 kit,,, rc 310, fmu 10:1disc, msd 6al,,,,,,,ok here it is, i had a holley fpr on my str rail and my fuel pressure was at about 40psi,, but my car is hesitating in vacuum, (mostly partial throttle) so i put back in a gsr fuel pressure regulator,,(which i am using when i put in my 2b next week) now my fuel pressure is about 50 psi or so,,,, and the Chiltons book i got said fuel pressure can be between 48psi and 55 psi>??? anybody have an answer for me??
thanks
Old May 31, 2003 | 08:17 PM
dfoxengr's Avatar
Default Re: What should my fuel pressure be at, need an answer quickly!!!! (DLOTYPER)
with fuel pressure 40 psi
at 1 pound, 50 psi, 2lbs 60, 3-70, 4-80..etc
Old May 31, 2003 | 08:33 PM
DLOTYPER's Avatar
i forgot some major **** here,, i need fuel pressure at idle,,,,, and i have a holley hp 255lph pump,,,, i am getting about 50 psi at idle with a stock regulator on the rail, what gives??
Old May 31, 2003 | 08:39 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
****, I'm only getting 37PSI at idle according to my Fuel Pressure gauges, and at MOST, I only see a max of maybe 60psi I think, but I'm only at 5psi.
Is that bad??? So far, I haven't had any probs though? My car has been tuned on the dyno at Payn Tech, there was no mention of anything.
Old May 31, 2003 | 09:53 PM
dfoxengr's Avatar
Default Re: (Snafu-Si)
the fmu increases fuel pressure due to which disc it has...
Old May 31, 2003 | 10:11 PM
Chrome Pipes's Avatar
Default Re: (hybridvteceg)
What up Dave. Just put in that Hondata already...let me know about that FMU
Old May 31, 2003 | 10:16 PM
DLOTYPER's Avatar
jay you homo!! Boosted hybrid is doing my hondata either monday or wednesday,,, he told me to use a stock fpr because it will keep idle fuel pressure at around 40 psi, but my ***** at 50 wtf? i dont know somebody chime in anytime
s0lid
Feb 20, 2012 04:01 PM
JdM_Eg6_SiiR
Jun 13, 2009 02:35 AM
scatuli
Mar 22, 2004 07:32 PM
IVANITR
May 6, 2002 07:16 PM
