Power steering noise
Old Jul 16, 2001 | 07:57 AM
sleepy's Avatar
Default Power steering noise
My steering makes a horrible noise when being turned. Please help me diagnose the problem.
Should I change the fluid and see?
is it totally shot?
96 GSR
Old Jul 17, 2001 | 08:35 AM
sleepy's Avatar
Default Re: Power steering noise (sleepy)
Stock fluid that has been in for 2 years.
Began 3 months ago.
Makes a WOOOOOOO!!! sound on turning, which is especially noticeable when accelerating while turning.
Fluid level in reservoir is at low end of normal.
Which connections along the steering column are likely to be bad?
Rack? Where it turns the wheels?
Help.
[Modified by sleepy, 10:36 AM 7/17/2001]
Old Jul 17, 2001 | 12:06 PM
Comptech98GSR's Avatar
Acura has a bulliten about that, mine did the same thing, all they had to do was lube up something behind the steering column. HOpe this helps.
Old Jul 17, 2001 | 06:12 PM
sleepy's Avatar
Default Re: Power steering noise (Comptech98GSR)
Thanks for the reply. I found the Service Bulletins on the NHTSA.com. What do I do know? Should I take it to Acura and ask them to fix it? It is not a recall, I think, so will they cover it at no cost?
How do I find information on the fix.
STi-Thrill
Dec 19, 2011 12:54 PM
sky9
Feb 25, 2011 02:40 PM
davidluko
Aug 31, 2006 07:16 PM
Nizzy
May 16, 2003 05:19 AM
Eskram
Jan 4, 2002 02:55 PM
