d15b7 16v delsol motor running on my d15b8 CX 8v motor's ECU
Old May 31, 2003 | 05:42 PM
riceburnah's Avatar
Default d15b7 16v delsol motor running on my d15b8 CX 8v motor's ECU
any problem with this? i blew my stock cx motor, swapping in a delsol 16v d15b7 motor into it. Thanks
Old May 31, 2003 | 06:13 PM
eg6ajk's Avatar
Default Re: d15b7 16v delsol motor running on my d15b8 CX 8v motor's ECU (ihaterice8)
no problems at all, just swap over your 02 sensor (if 1 wire type).
btw. the P05 ecu can easily be converted to P06 specs with a transistor + resistor + P06 EPROM (program).
Old Jun 1, 2003 | 05:06 PM
vw-honda-hatches's Avatar
Default Re: d15b7 16v delsol motor running on my d15b8 CX 8v motor's ECU (eg6ajk)
well i kept the 4 wire o2 on the motor compared to the 1 wire 02 that came on the stock cx motor. and it runs absolutely fine. ill check the plugs in a few days. thanks bro!!
Session101
Dec 5, 2003 05:16 AM
Session101
Dec 4, 2003 09:59 AM
riceburnah
May 31, 2003 08:13 PM
Civmochris
Nov 11, 2002 07:35 PM
