battery life
Old May 31, 2003 | 05:19 PM
civcexcoupeblack's Avatar
Default battery life
If my alternator was died, while my battery had a full charge, how long would the battery last, before my car died. I drive 2 hours a day i would say, maybe 30 of them are night time minutes
Old May 31, 2003 | 05:49 PM
zad5's Avatar
A person long ago from Kragens told me that it would only last around 10 minutes but im not sure. But the guy that told me that doesn't know what he is talking about but he might be right.
Old May 31, 2003 | 06:10 PM
Mohudsolo's Avatar
Default Re: (zad5)
Most batteries have both cold cranking amps (CCA) and amp hours (AH) listed. The AH is how much amperage the battery can put out for an hour. With fuel pump, ignition, injection, guages, and maybe lights I would guess around 20 amps to 30 with lights. So, if the battery is rated at 60 AH, it would go 2-3 hours if it had a full charge. Reality is probably less since most of the systems have a minimum voltage they work at and the voltage will be dropping as the battery loses charge. The problem is the alternator does not usually go from working fine to dead all at once, so when they fail, the battery does not have a good charge. If it happens, try not to shut the car off unless you are at a place where it can be fixed and get a jump or charge, since there is usually enough charge to run the car but not enough to run the starter.
Old Jun 1, 2003 | 01:32 AM
The-LS's Avatar
Default Re: battery life (civcexcoupeblack)
my old car made it about 1 day. Not a full day of driving of course, but maybe about a atotal of less than 1 hours of driving?
Old Jun 1, 2003 | 01:58 AM
thaiphob's Avatar
Nikon!!!
Default Re: battery life (Black-LS)
when my alternator crapped out on me it lasted about half an hour after a charge at nite from a gas station.
Old Jun 1, 2003 | 10:29 AM
Default Re: battery life (thaiphob)
does the alternator fuse blow when the alternator dies? b/c my fuse keeps blowing, and i cnat figure out why
mydogFahey
Honda CR-V & Element
10
Mar 29, 2015 09:59 AM
disposable
Jun 26, 2008 08:02 PM
Jizzo
Dec 18, 2007 03:43 PM
Si_chRis
Oct 21, 2006 03:36 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
