Looking to make close to 300 whp can I use vafc hack?
I am building a turbo kit and I am going to use a T25 or A t28 turbine because I want to be able to have a nice daily driver and have a good auto-x car. I have a 95 si hatch with a jdm gsr swap and will be using an inline pro head gasket. will I be able to get around 300 whp and will it be reliable with the vafc hack????
get a t3 with a smaller exhaust housing. 300whp is a lot for autox in a FF. You want low-mid 200's if anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst »</TD></TR><TR><TD CLASS="quote">I think the SMC handles up to 14psi or so.</TD></TR></TABLE>
the map sensor wont though, thats what the hack relies on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol »</TD></TR><TR><TD CLASS="quote">hack is only good to ~11 psi.
to hit 300 whp, you are going to need mroe than that from even an average size t3/t4</TD></TR></TABLE>
u can use the hack with 20 psi of boost...all u need is to upgrade ur map senor to a GM 3bar map sensor...then u wont run into any cel because of the stock map sensor
why not just get a missing link for $60 and not worry about the hack way. then with the correct size turbo, you can get your 300whp.
still don't understand why doing the HACK is all the hype. especially when the alternative only cost $60 more. ???????? feel free to let me know what the benefits are if any.
You can use the hack for any setup. But Liam explained it using 450s and could only go to 11 psi that is why people think it won't work over 11 psi. Sure it will. You will need a 3bar map sensor tho so you dont throw any codes but that would be all and injectors
True with 3bar map u can run beyond ~11psi.....but running that high a boost with the hack is suicide as you got no timing control. Unless you are running an external timing device but even so, for the money you'd be better and safe with standalone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng »</TD></TR><TR><TD CLASS="quote">especially when the alternative only cost $60 more. ???????? feel free to let me know what the benefits are if any.</TD></TR></TABLE> You still need something to tune your fuel and/or timing with. The Missing link wont do that for $60 bucks.
of course it won't tune. i ment for the EXTRA $60 over the cost of a SAFC/VAFC.
as for the 3bar map sensor. how will you set the calibration with a stock(unprogramable) ecu. to run a 3bar properly. you will need hondata or something along those lines.
riddickone
Nov 23, 2003 06:38 PM
