is a B17 block good for anything??
Old May 30, 2003 | 06:23 PM
Boostless97Lude
Guest
Posts: n/a
Default is a B17 block good for anything??
i've got a B17 block and crank, and a JDM B16 shortblock, both just chillin in my shop, i don't know what to do with them, i don't have jack that is b-series anymore, but something keeps telling me i could make something cool, i just don't know what, anyone got any ideas?
Old May 30, 2003 | 07:22 PM
Skeletor's Avatar
Default Re: is a B17 block good for anything?? (Boosted97Lude)
I'll buy it.
Old May 30, 2003 | 07:26 PM
EG6[B16A1]'s Avatar
Default Re: is a B17 block good for anything?? (Skeletor)
yeah, I have a B17 head, and a B16A1 block, can I do anyhing good to it??? what if I put the b17 head on the B16A1 block?? does that gain any power??? (B17 has been ported, the head)
Old May 30, 2003 | 07:38 PM
wHOAlly's Avatar
Default Re: is a B17 block good for anything?? (F15HMAN[BYM])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F15HMAN[BYM &raquo;</TD></TR><TR><TD CLASS="quote">]yeah, I have a B17 head, and a B16A1 block, can I do anyhing good to it??? what if I put the b17 head on the B16A1 block?? does that gain any power??? (B17 has been ported, the head) </TD></TR></TABLE>
b16 head=b17 head=pr3 casting, same ****
Old May 30, 2003 | 08:00 PM
riceboy's Avatar
Default Re: is a B17 block good for anything?? (Sp00n'd Supra)
I've always thought that the B17 would be a good motor to toy around with considering its unique rod ratio of 1.62 I believe. Being is it is the same thing as a B16A1 other than the crank, rods and pistons, I see nothing wrong with fixing one up, I'm not sure who makes aftermarket rods for that motor, but I'm thinking eagle or cunningham should. Bore or sleeve it to 85 mm, and its a 1.8L with a slightly faster moving piston than the B16 for a little added torque.
I say build it, boost it and post the results.
Old May 30, 2003 | 08:23 PM
b19coupe's Avatar
You could give it to me to play with, if you don't have the time
Old May 31, 2003 | 11:01 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: is a B17 block good for anything?? (b19coupe)
I'd love a B17A w/ O/S CTR pistons and CTR cams in a 99 H/B as my daily driver.
Old May 31, 2003 | 11:15 AM
bew
Guest
Posts: n/a
Default Re: is a B17 block good for anything?? (Mr Milano)
You could always send me that B16 block with my exhaust, so I can run that and build the LS block up to a 2.0LS/VTEC and laugh at ITR's :D
Old May 31, 2003 | 05:21 PM
RICE POLICE SIP's Avatar
Default Re: is a B17 block good for anything?? (bew)
Put the b17 crank and rods on the b16 block and have a 1.7L b16 or if you're looking to get rid of the crank then let me know cause i have an extra set of b17 rods laying around....
Old May 31, 2003 | 05:57 PM
J2turbo21's Avatar
I know a guy with a 92 GSr,the one that came with the b17 motor.It was gutted with Nitto drag radials,i/h/e,intake manifold,fuel rail and fpr,real skunk2 ecu and skunk stage 1 cams and he did a 14.0X with it.
Old Jun 5, 2003 | 06:20 PM
StorminMatt's Avatar
Default Re: is a B17 block good for anything?? (J2turbo21)
A B17A block is also good for Californians who want a reffable motor.
Old Jun 5, 2003 | 06:52 PM
dfoxengr's Avatar
Default Re: is a B17 block good for anything?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">A B17A block is also good for Californians who want a reffable motor.</TD></TR></TABLE>
yep reffable
Old Jun 12, 2003 | 09:25 PM
NA EP3's Avatar
ill take the B17 crank off your hands but, then ill need some rods hmmm......
sivtechatchy
Mar 6, 2009 03:45 AM
98_Coupe
Mar 31, 2007 07:09 PM
hmtcrxsir
Mar 25, 2006 04:27 PM
