1gen B16 GSR CAM SWAP questions before i start. HELP!
Old May 30, 2003 | 06:04 PM
W0oT's Avatar
Banned
Default 1gen B16 GSR CAM SWAP questions before i start. HELP!
ok so i was planning on swapping in my gsr cams into my 1 gen obd0 b16 tomarrow. i just want to make sure i do it right... well i was wondering.... can i do it w/ out removing the head? i've heard you can... and i have a couple of sites that kinda explain it.... just want to make sure.... plus how can i make sure which is which... i did a search too w/ no results.... here's the links:
http://hybrid2.honda-perf.org/tech/cams.html
http://www.c-speedracing.com/h...m.php
i'm sure i'm just being over carefull. but just want to be sure.
Old May 30, 2003 | 07:01 PM
keebler65's Avatar
Default Re: 1gen B16 GSR CAM SWAP questions before i start. HELP! (Nismo240sx1)
theres no reason at all that you'd have to remove the head. i dont know where you heard that, but it doesnt make sense. you only have to remove the cams if you're removing the head.
as far as telling which is which, you'll see the slot on the one cam that mates with the distributor, so they'll only fit in there one way.
make sure you do a valve adjustment once the new cams are in, since you will have different lift specs, etc.
Old May 30, 2003 | 09:47 PM
incubus's Avatar
Default Re: 1gen B16 GSR CAM SWAP questions before i start. HELP! (keebler65)
what do you mean by head? do u mean valve cover?
removing the whole head would make no sense.
Old May 30, 2003 | 11:04 PM
W0oT's Avatar
Banned
Default Re: 1gen B16 GSR CAM SWAP questions before i start. HELP! (incubus)
in the b16 fsm (online) it says to remove the head.... this is wrong because i've seen it done w/ out removing the head. i'm just gonna follow those 2 sites info... it seems acurate.
damnit i've never done a valve adjustment hope i don't f*ck up.
Old May 30, 2003 | 11:05 PM
W0oT's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">theres no reason at all that you'd have to remove the head. i dont know where you heard that, but it doesnt make sense. you only have to remove the cams if you're removing the head.</TD></TR></TABLE>
i'm removing my stock cams upgrading to GSR cams....
stupidity on my part.... should have known there'd be a slot in intake cam.
Old May 31, 2003 | 04:18 AM
Xsi's Avatar
Xsi
Also here: http://www.g2ic.com/tegtips/engine/26.html
Old Jun 4, 2003 | 08:46 AM
W0oT's Avatar
Banned
Default Re: (Xsi)
THANKYOU! looks just about the same as the instructions i had
Old Jun 5, 2003 | 08:08 PM
smokey2.0's Avatar
Default Re: (Nismo240sx1)
you won't need to take off the head, just follow the instructions in the link from cspeedracing. they have one of the best how to in the web, good luck!
spoolinvtec54
Apr 3, 2011 08:50 PM
dame-ningen
17
Mar 6, 2009 08:22 PM
staindgd
15
Sep 26, 2008 02:04 PM
nitrousfed
Mar 19, 2006 11:55 AM
flab1633029
Jul 22, 2004 09:56 PM
