-----I LOST MY ONLY KEY---- 0-^^
Old May 30, 2003 | 05:29 PM
jondancer's Avatar
Default -----I LOST MY ONLY KEY---- 0-^^
what now? i only had one ket for my crx it fit the doors and ignition and i LOST it
what do i do know???
thanks alot
Old May 30, 2003 | 05:31 PM
Malgerus's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (jondancer)
Go with your VIN to the dealer, as long as you have proof that it's yourc ar you should get a key. Or call a locksmith, I guess.
Old May 30, 2003 | 06:14 PM
4crx4me's Avatar
This same thing happened to me yesterday while unloading my B17
from the truck that delivered it
I called my local honda dealer, we're on a first name basis at this point.
They said, "Bring your Drivers liscence,Insurance card, and registration."
They need proof that the VIN# is correct and belongs to you and they will
cut you a new key"
HTH
Old May 30, 2003 | 07:32 PM
Patch's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (4crx4me)
You can also yank your lock cylinder out, so you can just start your car with a screwdriver. I'd try what the others told you first though.
Old May 31, 2003 | 03:41 AM
jondancer's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (CRX PAT)
so honda still keeps 89 crx records on file? thats sweet! my closest honda dealer is over an hour away
thanks
Old May 31, 2003 | 03:50 AM
90da's Avatar
What happens is we send your vin to Honda, and they send us a code to cut your key. The only problem is you will have to play with the key a bit because the key is brand new, you'll see what I mean we do it all the time.
Old Jun 1, 2003 | 08:08 AM
1's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (90ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90ef &raquo;</TD></TR><TR><TD CLASS="quote">What happens is we send your vin to Honda, and they send us a code to cut your key. The only problem is you will have to play with the key a bit because the key is brand new, you'll see what I mean we do it all the time.</TD></TR></TABLE>
Sand the burrs off.
Old Jun 1, 2003 | 08:33 AM
EG8R's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (1)
Why wouldn't you get one cut BEFORE you lost it if you knew it was your only key???
Old Jun 1, 2003 | 08:43 AM
jondancer's Avatar
Default Re: -----I LOST MY ONLY KEY---- 0-^^ (mr. skelly)
im lazy like that, and i been pretty busy , but thanks guys
Old Jun 1, 2003 | 09:12 AM
d357r0y's Avatar
You can also take the lock off of your door, it has a 4 digit code that you can take to a locksmith and they can cut you a new key.
Fnix
Apr 14, 2012 07:27 AM
EM1OwnerSi
14
Jan 10, 2007 08:06 AM
HondaRcB
Sep 8, 2006 10:07 AM
effinnwackk
12
Feb 21, 2005 05:03 PM
Nocturnal
12
Jan 7, 2003 09:09 AM
