skunk2 or jg edlebrock intake manifold
Old May 30, 2003 | 05:02 PM
sonicSVT's Avatar
Default skunk2 or jg edlebrock intake manifold
im going turbo in like a week and im buying all my parts and having them put on all at once. i was originally planning on getting a skunk2 intake manifold, but the guy at my shop said the edlebrock is like $30 more but makes more hp. can anyone confirm this, think its worth it? btw i have a 99 ls. thanks.
Old May 30, 2003 | 06:18 PM
Adriano's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (midnightls)
jg edelbrock
Old May 30, 2003 | 07:14 PM
TurboTeG4's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (brryder)
Someone mentioned in another post that the manifold kills driveability on the street.??
Old May 30, 2003 | 07:29 PM
B00STeD's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (turbocivic4)
jg manifold efficiency range is between 7000-10000 rpm's, almost useless power on the street.
Old May 30, 2003 | 07:37 PM
madman604's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (B00STeD)
would you say the efficiency is worse than OEM at 0-6000 rpm?
Old May 30, 2003 | 07:46 PM
B00STeD's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">would you say the efficiency is worse than OEM at 0-6000 rpm?</TD></TR></TABLE>
haven't heard or seen anything like that but from all the info I have seen on it, it's only more efficient from 7-10k.
Old May 30, 2003 | 07:51 PM
B18PoweredCivic's Avatar
Jg will give you gains from 7-10000 rpm...Skunk2 4-8000...I did skunk 2..i only take my car to 8500 so i get better use from Skunk 2
Old May 30, 2003 | 10:27 PM
B18Flip's Avatar
Default Re: (B18PoweredCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18PoweredCivic &raquo;</TD></TR><TR><TD CLASS="quote">Jg will give you gains from 7-10000 rpm...Skunk2 4-8000...I did skunk 2..i only take my car to 8500 so i get better use from Skunk 2</TD></TR></TABLE>
wow good info
Old May 30, 2003 | 10:31 PM
madman604's Avatar
sounds like a plan
Old May 30, 2003 | 10:37 PM
SiR Kid's Avatar
New User
Default Re: (Turbo E)
ITR manifold on my car... I've heard of some pretty decent HP gains over stock B16a/B18a or b.
Hell, Kubo went 9's on a Stock ITR that was Extrude Honed, how bad can it be?
Old May 31, 2003 | 05:16 PM
sonicSVT's Avatar
exactly what i was looking for, thanks
Old May 31, 2003 | 07:27 PM
Quick 200k Mile Motor's Avatar
Default Re: (midnightls)
the edlebrock is lacking torque
the only other choice is skunk2
Old Jun 1, 2003 | 05:55 AM
Cole D's Avatar
Default Re: (Quick 200k Mile Motor)
the jg is better for Turbo period........ na street car would benefit from a skunk2 but jg owns turbo
Old Jun 1, 2003 | 08:14 AM
sonicSVT's Avatar
alright, now im kinda confused...so whats the final verdict. i have an ls turbo, so i have a 7000 redline, but i have a turbo...? so im thinking of still going with the skunk maybe.
Old Jun 1, 2003 | 09:20 AM
tony1's Avatar
As far as i've seen, if you plan on making over 400whp and reving over 8500 then the jg will be best for your application. Anything less than those numbers you should go with the skunk 2. Bigger is NOT always better, it's about having the right combination.
Old Jun 1, 2003 | 11:19 AM
RuthlessEF-9's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (tony1)
skunk2 is the **** i would go with that its kind of more sleeperish you can get away with saying its stock to your buddies or anyone one else you talk story with on the street
Old Jun 1, 2003 | 11:25 AM
mysideperformance's Avatar
ok Personally if your going turbo and going for power go with the biggest intake manifold you can get, not the most "sleeperish" lol....try looking into a venom intake manifold...if you want power the bigger the plenum the better...horse power is all about air and fuel...the more of each makes the car faster...but hey thats your opinion
Old Jun 1, 2003 | 11:44 AM
LshatchTurbo's Avatar
New User
Default Re: (mysideperformance)
For your guys reference, the two manifolds side by side:
Old Jun 1, 2003 | 12:48 PM
turbospool's Avatar
what about the JG VS the STR, VENOM, GOLDEN EAGLE box sheetmetal manifolds?
Old Jun 10, 2003 | 08:28 PM
GOLDBERG's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (turbospool)
up..need..info... i thought the skunk was only good for n/a????
Old Jun 10, 2003 | 10:10 PM
W.Zero's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (GOLDBERG)
im using the JG for the street and mines is running real good. i had the itr on mine to begin with, which to me is not to much different from the skunk. but for daily driving it not different at all only when i get from 6700 to 9700 is where i love it the most. i would go with JG all the way!!!
i found in lower RPM it feels the same as my itr.
i havent dyno yet but going to shawn church real soon.
Old Jun 10, 2003 | 10:27 PM
miller's Avatar
Default Re: skunk2 or jg edlebrock intake manifold (W.ZeroB18C1T)
endyn seems to be the most thought out manifold on the market as of late.
Old Jun 11, 2003 | 10:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.ZeroB18C1T &raquo;</TD></TR><TR><TD CLASS="quote">i would go with JG all the way!!!
i found in lower RPM it feels the same as my itr.</TD></TR></TABLE>
did you keep your comp ratio same as stock?
Old Jun 11, 2003 | 10:49 AM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">As far as i've seen, if you plan on making over 400whp and reving over 8500 then the jg will be best for your application. Anything less than those numbers you should go with the skunk 2. Bigger is NOT always better, it's about having the right combination.</TD></TR></TABLE>
i agree with that, as well with some of the other thoughts.
if you're using higher boost levels with higher rpm limits (such as in a "track" car that may be driven on the street also) then go with JG IM for increased power. but if using a more mild turbo setup with less boost the Skunk2 IM should work great for most applications, good midrange and high rpm power. not just high rpm power like the JG IM.
i was going to sell my Skunk2 IM and buy a JG for my turbo motor, but i realized and decided that for my boost levels and targeted power output the Skunk2 would be best so i kept it.
Old Jun 11, 2003 | 10:50 AM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbospool &raquo;</TD></TR><TR><TD CLASS="quote">what about the JG VS the STR, VENOM, GOLDEN EAGLE box sheetmetal manifolds?</TD></TR></TABLE>
good question, i'd like to know more about those other brands as well.
