Did some mizzad GTECH testing. Fear my trap speed.
Old May 30, 2003 | 02:06 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Did some mizzad GTECH testing. Fear my trap speed.
Well I finally got my new exhaust on the car and it seems to have opened her up a good bit. I also haven't ran the car at the track sine I did some fuel tuning with my new cams. That said I wanted to go out and see what I could pull with the ole GTECH. Laugh all you want but if properly leveled I have found the GTECH to be VERY accurate in terms of ET's in relation to my track times. However the trap speeds have generally been a few mph high. I trusted the GTECH fairly well as a general estimate until today.
First run:
0-60mph....5.54sec. Had a good launch and that seemed about right.
1/4mi......13.5 Heck yeah! Ran a 13.7 with 173whp and now had 180+ so I figured that could be pretty close.
Trap speed..... a snail like 118mph!!! Seems like the GTECH is just a tad bit off.
Second run:
0-60mph....5.58
1/4mi....13.5
Trap speed.....117mph
The ET's seem like they could be close, but unless that new exhaust found another 90whp or so I think the GTECH might be off.
Old May 30, 2003 | 02:12 PM
AK94GSR's Avatar
Default Re: Did some mizzad GTECH testing. Fear my trap speed. (ActiveAero)
yeah, ive noticed the same thing to, its usually off by quite a bit on the mph
but usually accurate on the times
im pretty sure u could run at least a 13.5
get to the track dammit
Old May 30, 2003 | 02:13 PM
Dirt's Avatar
'Bama roads make you faster. I should have kept my GTECH to play with when I'm bored.
Old May 30, 2003 | 02:15 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: Did some mizzad GTECH testing. Fear my trap speed. (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR &raquo;</TD></TR><TR><TD CLASS="quote">yeah, ive noticed the same thing to, its usually off by quite a bit on the mph
but usually accurate on the times</TD></TR></TABLE>
Isn't this due to the fact that at the track they take the avg. speed over a short portion(im not sure how long) at the end of the 1/4 mile and with the GTECH it just uses your speed at the end of the 1/4 mile. Or am I just making this **** up as I go?
Old May 30, 2003 | 02:25 PM
Type-Rare#1248's Avatar
Default Re: Did some mizzad GTECH testing. Fear my trap speed. (ReBornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReBornGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't this due to the fact that at the track they take the avg. speed over a short portion(im not sure how long) at the end of the 1/4 mile and with the GTECH it just uses your speed at the end of the 1/4 mile. Or am I just making this **** up as I go?</TD></TR></TABLE>
i heard of that before too
Old May 30, 2003 | 02:34 PM
Chris N's Avatar
Default Re: Did some mizzad GTECH testing. Fear my trap speed. (Type-Rare#1248)
I thought the trap speed was the average speed in the last 66 feet of the track.
Old May 30, 2003 | 02:38 PM
Grumpy Old Man
Default Re: Did some mizzad GTECH testing. Fear my trap speed. (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">I thought the trap speed was the average speed in the last 66 feet of the track.</TD></TR></TABLE>
Yeah that's what I was trying to get at. And the gtech measures the speed right at the end so it will be a little higher
Old May 30, 2003 | 02:47 PM
Chris N's Avatar
what do we expect his trap speed to be at 13.5?
I thought it was a bit high, but I'm having trouble seeing how averaging the final 66ft would lower his speed that much...
either way, gtech is a bit high.
Old May 30, 2003 | 03:16 PM
ArmyGreenITR's Avatar
i used gtech before in one of my civics i too noticed that it s was really close on teh ET but way off on the trap speed
Old May 30, 2003 | 07:40 PM
ViZ's Avatar
ViZ
is this the old gtech or the newer version that you guys have used.. i have thought about purchasing one
Old May 31, 2003 | 07:24 AM
RICHJ's Avatar
Yeah that's what I was trying to get at. And the gtech measures the speed right at the end so it will be a little higher </TD></TR></TABLE>
Yes that is the case it is explained on the GTECH website and the leaflet that comes with the unit.
Old May 31, 2003 | 07:42 AM
jonas's Avatar
i tried a newer gtech.. it said i ran a 12.6 @ 155 mph LOL. i think we set it wrong
Old May 31, 2003 | 07:52 AM
jond's Avatar
Default Re: (jonas)
With gtech, do you need to enter the veichle weight to do the 1/4 mile times or just for it to calculate horsepower?
Old May 31, 2003 | 09:40 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">With gtech, do you need to enter the veichle weight to do the 1/4 mile times or just for it to calculate horsepower?
You only enter vehicle weight for hp. I've played around with the GTECH many times before and it has never been this far off. It's usually only 2-3mph off on the traps. I expect my traps to be close to 102mph meaning I was expecting GTECH to read 104-106mph.
If you calibrate the GTECH correctly (get it dead level) and run on a level road it has no choice but to be close. Acceleration (measured in G's)x time= distance. However there is no substitute for a real drag strip.
BLK99VTECR
Oct 28, 2003 09:53 PM
RacerXintegra2k
Jul 26, 2002 01:03 AM
CRXRageD
May 6, 2002 08:27 AM
DelsolVtec18
Oct 4, 2001 12:15 PM
