all motor b18cr
Old May 30, 2003 | 01:45 PM
JBk24crx's Avatar
Default all motor b18cr
well built how much horsepower can i get out of a all motor type r. what would it take to get 230 whp, import builders is 40 minutes away money no problem just looking for advice what cams, compression rods and other misc stuff. need help
Old May 30, 2003 | 01:54 PM
Finest's Avatar
Default Re: all motor b18cr (rub760)
If IB is 40 mins away, and money is no object....then I think you know where you're going.
Seriously, they're good guys that will build you a great motor. Just that their prices are...well, you know. You definitely get what you pay for.
BTW, look for 12.5:1+ CR, Stage 2+ cams, and lots of dyno time. 230whp is do-able...out there, but do-able. Remember, all of your power is in the head.
Old May 30, 2003 | 01:55 PM
FrankEXsteiN's Avatar
if money is no object, i would build it right. add some sleeves. maybe an overbore to a 2.0L. 12.5 or 13:1 comp. forged pistons. some H-beam rods. toda or jun race cams with titanium retainers and dual valve springs. re-bearing the entire motor and redo all the components (e.i. water pump, oil pump, timing belt, etc....) Lastly, hondata and a badass tuner. with all this done, i could imagine well over 200+ to the wheels.
Old May 30, 2003 | 02:05 PM
98itR484's Avatar
Default Re: all motor b18cr (FrankEXsteiN)
Well i believe that when you pull the motor there is NO reason not to replace all bearings, oil pump, water pump etc etc etc if you dont then i think its being sloppy and doing a "half-***" job.
Take the car to autolink in Temple City, CA, 230whp should be no problem to do, these days 230 is a joke to most racers, which is sad for normal people like myself
You can go B20, get some RS sleeves, nice p&p job from portflow, JUN3s or JUN4's if you are that crazy, some nice pistons/rods (your choice, 13:1 i would prefer), a nice header, a SMS header would be good.
Take it to autolink have them put it together and throw it on the dyno to be tuned by the Doc himself.
Old May 30, 2003 | 02:08 PM
Footwork's Avatar
i got 228whp out of my 1.8 which cost me around 9-10 grand (crate engine/motec tuned).
Paul
Modified by Primo. at 12:00 AM 5/31/2003
Old May 30, 2003 | 02:33 PM
dkim48's Avatar
Default Re: all motor b18cr (Primo.)
If money is no object http://www.ericksracing.com
simply the best NA honda builder period.
Old May 30, 2003 | 05:52 PM
98itR484's Avatar
Default Re: all motor b18cr (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">If money is no object http://www.ericksracing.com
simply the best NA honda builder period.</TD></TR></TABLE>
argueable statement
to all the great honda builders
Old May 31, 2003 | 11:09 AM
Mr Hammond's Avatar
a/k/a Jomo
I've seen as high as 19X's on stock long blocks bolt-on's and much tuning. I think O/S PCT pisotns and thin head gasket or mild mill. Right around 12ish:1. Spec C's and valvetrain, little port work, all the bolt-on's SMSP or Hytech header back, Hondata + Jeff & Jerry. I think you'd be ok and happy with the results you would get. If money is no object then just buy this.
Since 1983
14
Oct 11, 2009 05:41 PM
jacobolito
Dec 9, 2006 04:19 PM
BB4
Jun 16, 2006 03:54 PM
92LSVTEC
May 1, 2005 08:10 PM
MissMyHonda
15
Feb 8, 2004 05:27 PM
