cleaning headlights?
Old May 30, 2003 | 12:39 PM
Jebus's Avatar
Default cleaning headlights?
AFter I blacked my headlights i couldn't help but notice how dirty the plastic covers are...
can anyone recommend how to clean them up so the sparkle like new??
thanks
Jon
Old May 30, 2003 | 02:42 PM
JDMC5's Avatar
Default Re: cleaning headlights? (Jebus)
I used Rubbing Alcohol to clean my housing. Anything will work that will dissolve over time, and wont leave moisture, and wont mess up the plastic.
Old May 30, 2003 | 03:20 PM
haccord2.2's Avatar
Default Re: cleaning headlights? (Slow-R)
Well what do you mean by plastic covers? If you mean the Clear lense that goes on the outside of the headlight, then I would use a clay bar on it and work on it for a while then just clean, and put some Meguiars Hi-Tech yellow wax on the lense and It will look like new again. Hope this helps.
Old May 30, 2003 | 06:18 PM
Jebus's Avatar
thanks guys
i was a little fague on details but i have a 97 hatch...and the lense is soo dirty. the inside is ok since its never exposed but the outside is horride...
ill try what you suggested Haccord2.2
thanks
Old May 30, 2003 | 07:04 PM
Inigo Montoya's Avatar
Default Re: (Jebus)
avtually the 96-98 lenses have a horrible habit of turning yellow. I know, i have a 98. the solutions are getting some polishing stuff, getting a polishing disk that you can put on a drill, and hoping that helps.
otherwise you have to go aftermarket.
I have cleaned mine but they still look crappy, if i use car wax on them they do look a bit better.
dc2long
Mar 30, 2007 02:58 AM
thomst4R
Jul 24, 2005 04:58 AM
streakz
Jun 13, 2003 02:26 PM
CivicBoi
Jul 21, 2002 07:30 PM
Jesse H
Jan 7, 2002 01:31 PM
