Help w/ Timing belt slipping
Old May 30, 2003 | 10:34 AM
Bspec18's Avatar
Default Help w/ Timing belt slipping
When i got my valve adjustment done my mechanic said that my timing belt seems kinda loose. Anyways this was a month ago and lately when im in boost it seems to sputter as if it was detonating. so i'm guessing its the timing belt right ? Also other than yanking on the belt to see if theres tention or not, is there anyway i can verify that the belt maybe jumped a tooth ?
Old May 30, 2003 | 10:53 AM
Bspec18's Avatar
Default Re: Help w/ Timing belt slipping (Bspec18)
awww.....someone knows
btw did a search too
Old May 30, 2003 | 11:25 AM
RGAZ's Avatar
New User
Hello, find TDC pull the TB cover and verify pulley TDC matches cam TDC. Voila!! You know know if the belt jumped a tooth.
To adjust tension, read your manual. it goes something like loosen tensioner, crank three teeth then retighten. Easy-peasy.
R
Old May 30, 2003 | 11:28 AM
Bspec18's Avatar
Hey thanks for the response, luckily i cut the valve cover to see the cam gears so i dont have to remove anything. I sure hope it did jump and this is the problem and nothing internal
LS_VTECteggy
Jun 11, 2010 01:34 PM
thegatekeeper14
Aug 5, 2009 03:28 PM
thebleek
15
Sep 15, 2008 04:06 PM
phatstyles
May 13, 2005 10:55 PM
LudeyKrus
Sep 3, 2004 11:22 AM
