whats the widest tire you can use on a 5th gen?
Whats the widest you can possibly get without rubbing? This is just a decieding factor when I get rims, so it's not for stock rims or even a set rim width. I want to find the widest tires first, then match the rims to them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude »</TD></TR><TR><TD CLASS="quote">i'd say a 235 tire or wider is pushing it</TD></TR></TABLE>
I run a 225/35zr18...it's close but doesn't rub even with my teins at their lowest. Any wider and unless you've got a perfect offset on whatever wheel you choose and you're likely gonna rub. Any particular reason for wanting extremely wide rubber?
--Ian
--Ian
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB »</TD></TR><TR><TD CLASS="quote"> you're just hurting your acceleration with 18s. </TD></TR></TABLE> anything shorter, and i'd NEVER hook up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude »</TD></TR><TR><TD CLASS="quote">AH HA!!! i KNEW i wasn't the only ricecake rolling 18s on a 5th gen</TD></TR></TABLE>
heh, busted...but at least mine are black.
--Ian
--Ian
Yeah, 235's the widest I've heard of without rubbing. You might be able to get wider in there, but not without modifying the brake calipers to not stick out as much so you can fit a higher offset wheel. Also depends on your negative camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SsTiNgEr77 »</TD></TR><TR><TD CLASS="quote">pics? </TD></TR></TABLE>
Don't mind the ricey stickers...long since gone.
--Ian
--Ian
nice ride, im surprised the 18's fit with lowered sus, i think 17's might rub on mine :\ but that might just be becaues i'm wearing falkens instead of like the lower profiled toyo's etc.
ps. the FMIC is looks sick
BB6Paul
Jan 3, 2006 03:11 PM
