The Godspeed Spec C Package
Old Jul 15, 2001 | 05:54 PM
blackR#663's Avatar
New User
Default The Godspeed Spec C Package
What change can i expect from the godspeed spec c package?
Toda Spec C Cams
Cam Gears
Valve Springs
Ti Retainers
Godspeed ECU
440cc Injectors
Old Jul 15, 2001 | 05:59 PM
AllMotorITR's Avatar
New User
Default Re: The Godspeed Spec C Package (blackR#663)
You will be hitting well over 200whp with tuning! But for a daily driver I wouldn't recommend it.... I'd go with Spec Bs for daily driver....
Old Jul 15, 2001 | 06:04 PM
Reid's Avatar
Global Moderator
Default Re: The Godspeed Spec C Package (PYTypeR408)
Would you care to give a reason why you would rather have Spec B's than Spec C's for a daily driver? Idle is the same. I will be ordering a set of Spec C's for my ITR when funds allow. Who wouldn't like more power?
Old Jul 15, 2001 | 06:12 PM
FSTASNTZ's Avatar
I have been running Spec Cs on the street for almost a year now.
Jason
Old Jul 15, 2001 | 06:13 PM
FSTASNTZ's Avatar
As for power. What other mods are on the car. The intake/header/cat/exhaust combo can make or break that setup.
Jason
Old Jul 15, 2001 | 06:29 PM
VTEC4GS's Avatar
I'm sure god will explain that for the 200hp mark you should at least get a relatively high compression block ... with my C packages I usually have LS or GSR or even b16a blocks built up for people with simple CTR pistons to run with that similar package.
Greg
Old Jul 15, 2001 | 07:01 PM
New User
Default Re: The Godspeed Spec C Package (vtec4gs)
From reading, and listening to owners of both Spec C and Bs, I was under the impression that they had different idles, and that the Spec Cs were not as streetable as the Bs.. If I am wrong I am sorry...
Old Jul 15, 2001 | 07:41 PM
Vazquez911's Avatar
Default Re: The Godspeed Spec C Package (ILOVERACING)
The site can say all it wants... owners of both the C's and the B's have stated for well over the past year... the C's are not NEARLY at streetable as the B's. At times the C's find themselves stalling the engine... Though Steve doesn't mind having to restart his R equipped Cs...
Oh wait... it's on the net... thus it's true... my fault.
Old Jul 15, 2001 | 08:24 PM
BlackGSR's Avatar
It's all in the tuning.
Both cams have the SAME NON-VTEC lobes. That means the same idle.
Old Jul 15, 2001 | 08:26 PM
slowerthanu's Avatar
New User
Default Re: The Godspeed Spec C Package (BlackGSR)
Thus the reason I bought JUN type-3's Idle like stock plus mad top end.
Old Jul 15, 2001 | 08:56 PM
Mike M's Avatar
Founding Member
Default Re: The Godspeed Spec C Package (slowerthanu)
For C's I reccomend the following as a Package
CTR Pistons
Toda Spec C cams
Toda cam gears
Ferrea Retainers
Toda valvesprings
Toyota Injectors (they are 430cc not 440cc)
Reprogrammed ECU
J&R Safegaurd
Complete package is about $3900
Old Jul 15, 2001 | 10:22 PM
Dipshit Dan's Avatar
Default Re: The Godspeed Spec C Package (TypeRmsm)
Just for the record yes B's and C's idle the exact same way. C's just have more requirements in terms of necessary mods and clearances that the B's don't have. And yes, the injectors are 430cc. Sorry for the mistake folks. I guess I've been around too many MR2's or something.
Old Jul 15, 2001 | 10:33 PM
TodaSi's Avatar
Default Re: The Godspeed Spec C Package (God)
I can't believe this Spec B and spec C stuff is going on. How many times has it been covered the Spec B cams have the same primary lobes as the Spec C cams?
Anyway, daily driver, no problems. I would suggest with both the B's and C's you adjust your valve lash every 10,000 miles, replace your timing belt every 35,000 miles, and keep everything else generally well maintained... as I'm sure most do
Old Jul 16, 2001 | 05:12 AM
newspeedR's Avatar
so you saying people runnng ls/vtec with CTR pistons and C's with have no problems...
Old Jul 16, 2001 | 08:56 AM
Black R's Avatar
25 Year Member
Default Re: The Godspeed Spec C Package (TodaSi)
10k miles on the adjustment? I was planning on checking at each oil change...
BTW: is there a torque spec on those screws to tighten in place after you have made the adjustment? Let me double-check with Eric...
Old Jul 16, 2001 | 08:57 AM
Black R's Avatar
25 Year Member
CTR Pistons
Toda Spec C cams
Toda cam gears
Ferrea Retainers
Toda valvesprings
Reprogrammed ECU
J&R Safegaurd
Why the ferrea retainers? Portflow not good enough?
Old Jul 16, 2001 | 06:08 PM
Mike M's Avatar
Founding Member
Default Re: The Godspeed Spec C Package (Black R)
I like the quality of Ferrea's Products and for $40 more they are worth it.
dt4life
Mar 7, 2005 11:31 PM
dohcbag
Aug 19, 2004 02:27 PM
bitr364
Mar 9, 2003 12:54 AM
Black R
Feb 2, 2002 09:10 AM
00 Si
13
Sep 19, 2001 07:16 AM
