Do i need SI or DX knuckles for my 1988 HF if putting B16a?
Old May 29, 2003 | 09:09 PM
88crx Osaka's Avatar
Default Do i need SI or DX knuckles for my 1988 HF if putting B16a?
I did use the search and still im not sure.
What the topic say. Im not sure if i need to get those knuckles. On hasport it says that you have to "For a good fit, the axles and car will have to be modified by removing the spacer in the hub and removing the dust seal on the outer joint." Is that correct? And it doesnt say what models.
So if i need to get dx or si knuckles are the ones from EF civic hatchback dx or si are the same as crx knuckles?
90-91 Civic EX sedan steering knuckles would those fit on my crx with B16a cuz i would like to upgrade the brakes at the same time. In my CRX, rotors and calipers are way to small to stop 160hp monster.
One more thing i saw topic long time ago and cant find it. It was about usind 90-93 Integra engine mounts in 88-91 CRX with B16a. Is that truth or just cowshit?
Thanks for help.
Old May 29, 2003 | 09:30 PM
incubus's Avatar
Default Re: Do i need SI or DX knuckles for my 1988 HF if putting B16a? (88CRX)
yes u need SI or DX, if u use SI I believe u can use ur HF calipers.
or u could just get TEG knuckles n calipers and get the fastbrakes upgrade kit.
If u keep runing ur HF rotors they will be warped in no time.
http://www.fastbrakes.com check out the kit.
northemt88
Apr 30, 2008 10:15 AM
JDM_EK_JOE
Feb 16, 2006 08:01 AM
Steemo
Jun 29, 2004 03:47 PM
Rob!
Sep 23, 2002 11:53 AM
KoRE
Feb 28, 2002 07:52 AM
